| | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | Has anyone used the Fenton cast iron headers? I took the truck for its first drive today and it has a pretty bad exhaust leak. I am concidering a new exhaust system since the one on there looks to be in pretty bad shape. Has anyone used these headers? Are these the way to go or would I be better off re-condition the old manifold?
Thanks. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The Fentons can be made to fit a gmc engine, but it takes a bit of grinding. The Fentons are actually made to fit the Chevy engines. There were other cast iron manifolds available for the 228-302 gmc motors but they are rather difficult to come by.
I will be using a set of Fentons on my 302 Jimmy. If I had it to do again, I would look for a set of headers that was specifically cast for the gmc engines. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter (and others) sells a Chevrolet and a GMC set of Fenton headers. Is the GMC set not a good fit on GMC 228-302 engines? | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I put Fentons on my Chevy 261 and it still takes grinding if you're matching them up to a different intake such as an Offy. They sound great with Patrick's dual stainless steel exhaust system. http://community.webshots.com/user/geezer | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Fentons were cast up originally for Chevrolets, and then for GMC's, the right castings will fit either engine. I have Fentons on my GMC 248 and they fit fine. A little bit of grinding to port match might be needed, but that's good practice for any new manifold. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The Fentons they sell for the GMCs are actually cast for the Chevys. The only difference is where the hole is drilled to mount to the cylinder head. I say hole because there is only one per manifold. You may need to grind a bit of material off the front side too in order to get those GMC washers to have a surface to grab.
I am not trying to bash the Fenton headers, I am only trying to pass on the fact that they are not a direct bolt on replacement. It may take a couple of afternoons to get them tweaked just right. In all a very rewarding little project.
P.S. Don't forget about plumbing the manifold heat! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Seems that they need grinding regardless of whether you use them on a Chevy or GMC, especially with an Offy intake. I'll pass along 3 things I did that helped on mine, 1- replace the 2 outside guide pins with bolts/threaded studs. This gives a little more even clamping and will help stop leaks at the outer ends of the manifolds. 2-Replace the other manifold bolts with studs. Makes for easier installation and seem to torque down better that the bolts do. 3-Forget using the original manifold clamps, they're just a pain to make work right without exsessive grinding, followed by extensive foul language when they don't fit right. I made new ones from 1/4" stainless flat stock. Much better for clamping the manifolds and they won't get on a funny angle or try to shift on you when you tighten them down.
Bill Burmeister | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Fentons are the best mod. ive ever done to all of my old stovebolts. Theyre money well spent. Marty | | |
