4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#233422 05/07/2007 4:15 AM
Has anyone used the Fenton cast iron headers? I took the truck for its first drive today and it has a pretty bad exhaust leak. I am concidering a new exhaust system since the one on there looks to be in pretty bad shape. Has anyone used these headers? Are these the way to go or would I be better off re-condition the old manifold?
Thanks.
#233423 05/07/2007 6:21 AM
The Fentons can be made to fit a gmc engine, but it takes a bit of grinding. The Fentons are actually made to fit the Chevy engines. There were other cast iron manifolds available for the 228-302 gmc motors but they are rather difficult to come by.
I will be using a set of Fentons on my 302 Jimmy. If I had it to do again, I would look for a set of headers that was specifically cast for the gmc engines.
#233424 05/07/2007 10:50 AM
Jim Carter (and others) sells a Chevrolet and a GMC set of Fenton headers. Is the GMC set not a good fit on GMC 228-302 engines?
#233425 05/07/2007 12:33 PM
I put Fentons on my Chevy 261 and it still takes grinding if you're matching them up to a different intake such as an Offy. They sound great with Patrick's dual stainless steel exhaust system.
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
#233426 05/07/2007 3:45 PM
Fentons were cast up originally for Chevrolets, and then for GMC's, the right castings will fit either engine. I have Fentons on my GMC 248 and they fit fine. A little bit of grinding to port match might be needed, but that's good practice for any new manifold.
#233427 05/08/2007 12:13 AM
The Fentons they sell for the GMCs are actually cast for the Chevys. The only difference is where the hole is drilled to mount to the cylinder head. I say hole because there is only one per manifold. You may need to grind a bit of material off the front side too in order to get those GMC washers to have a surface to grab.
I am not trying to bash the Fenton headers, I am only trying to pass on the fact that they are not a direct bolt on replacement. It may take a couple of afternoons to get them tweaked just right. In all a very rewarding little project.
P.S. Don't forget about plumbing the manifold heat!
#233428 05/08/2007 1:21 AM
Seems that they need grinding regardless of whether you use them on a Chevy or GMC, especially with an Offy intake.
I'll pass along 3 things I did that helped on mine, 1- replace the 2 outside guide pins with bolts/threaded studs. This gives a little more even clamping and will help stop leaks at the outer ends of the manifolds. 2-Replace the other manifold bolts with studs. Makes for easier installation and seem to torque down better that the bolts do. 3-Forget using the original manifold clamps, they're just a pain to make work right without exsessive grinding, followed by extensive foul language when they don't fit right. I made new ones from 1/4" stainless flat stock. Much better for clamping the manifolds and they won't get on a funny angle or try to shift on you when you tighten them down.
Bill Burmeister
#233429 05/08/2007 1:27 AM
Fentons are the best mod. ive ever done to all of my old stovebolts. Theyre money well spent.
Marty
