6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#233021 04/30/2007 2:28 PM
Was wondering if anyone out there has found a vendor who can manufacture a hinged soft bed cover for a 54 truck?
I like the "Tonneau Masters" covers that are hinged about 8" back from the front. They will only custom make a fixed cover, so I was thinking about buying a full sized late model cover, cutting down the frame to fit...working up my own method of fastening down the front or hinged area (no internal lips on 54 bed) and having the cover cut down at a local canvas shop.
If any of you have bought or fabricated a hinged bed cover I sure would appreciate your input. BTW...I have a custom soft cover from Checker on my other truck but they are no longer making the soft covers and they need 4-6 weeks to deliver their custom hard cover. I need it sooner!
Thanks in advance,
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#233022 04/30/2007 4:28 PM
i am sure someone will correct me if this not right, but i think the bed is the same on the 54 up to 82 chevys. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#233023 04/30/2007 6:09 PM
WEbOLD, you're right on the beds from '54 to '82 they are all dimensionally the same. There are some slight differences in the bed side stampings but all will fit.
#233024 05/01/2007 2:36 AM
Thanks guys! Only problem is that most all the applications are for 82 and up. However, I'm going to use a later model application which is the correct length and cut the frame down to fit the width of the bed. Will have the cover narrowed at a local boat cover/canvas shop. Will have to fabricate some mounting clamps as there is no internal lip for conventional clamping systems.
The frames are just extruded aluminum with slip-in corner reinforcements. Gotta measure 3 times and cut once....not looking for hard cover security, just enough to keep the bed contents relatively dry while on the road. Will let you know how it works out.
Dave
#233025 05/01/2007 3:22 PM
The latest LMC truck catalogue has a Tonneau Cover for 60-66 Chevy trucks. Thet cost about $370 and fits Fleetside trucks. I am thinking about buying one if I can't find a fiberglass cover. LMC's website is LMCtruck.com. Hope this helps. Let me know if you have a source for the hard covers that will fit my 62 /2 ton short bed fleetside Chevy.
Green Machine
