| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Was wondering if anyone out there has found a vendor who can manufacture a hinged soft bed cover for a 54 truck?
I like the "Tonneau Masters" covers that are hinged about 8" back from the front. They will only custom make a fixed cover, so I was thinking about buying a full sized late model cover, cutting down the frame to fit...working up my own method of fastening down the front or hinged area (no internal lips on 54 bed) and having the cover cut down at a local canvas shop.
If any of you have bought or fabricated a hinged bed cover I sure would appreciate your input. BTW...I have a custom soft cover from Checker on my other truck but they are no longer making the soft covers and they need 4-6 weeks to deliver their custom hard cover. I need it sooner!
Thanks in advance,
Dave | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i am sure someone will correct me if this not right, but i think the bed is the same on the 54 up to 82 chevys. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | WEbOLD, you're right on the beds from '54 to '82 they are all dimensionally the same. There are some slight differences in the bed side stampings but all will fit. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Thanks guys! Only problem is that most all the applications are for 82 and up. However, I'm going to use a later model application which is the correct length and cut the frame down to fit the width of the bed. Will have the cover narrowed at a local boat cover/canvas shop. Will have to fabricate some mounting clamps as there is no internal lip for conventional clamping systems.
The frames are just extruded aluminum with slip-in corner reinforcements. Gotta measure 3 times and cut once....not looking for hard cover security, just enough to keep the bed contents relatively dry while on the road. Will let you know how it works out.
Dave | | | | | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | The latest LMC truck catalogue has a Tonneau Cover for 60-66 Chevy trucks. Thet cost about $370 and fits Fleetside trucks. I am thinking about buying one if I can't find a fiberglass cover. LMC's website is LMCtruck.com. Hope this helps. Let me know if you have a source for the hard covers that will fit my 62 /2 ton short bed fleetside Chevy.
Green Machine
