0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#232409 04/22/2007 4:36 AM
Hi,
Are there any special tools needed to do a brake job on a 41 Chevy with huck brakes?
Jeff
#232410 04/22/2007 11:47 AM
I used everyday stuff out of my toolbox. A third hand is useful in pulling the return spring across to both shoes.
1936 GMC T-14 1/2-Ton Pickup
#232411 04/22/2007 2:50 PM
not really.
You'll need a slotted screwdriver, a hammer, and a pair of vice-grips.
If you're putting in new wheel cylinders, then you'll need a ratchet or wrenches.
I can't remember what size bolt head are on those but I think it's 7/16" or 1/2".
The tubing flare nut size is 7/16" (use a tubing wrench), and you'll need a 5/8" open-ended wrench for the hoses.
Quote
I use my knee on one shoe, and the vice-grips to stretch the spring out. I've got a pair of spring pliers and they're just about worthless for Huck Brakes.
The conical springs with the J hooks on the front wheels can be kind of tricky, too. Vice-grips make a difference there, too.
#232412 04/22/2007 4:37 PM
You will need something to keep the cylinders from coming apart when the shoes are off. Tie wrap does a pretty good job.
1951 1 Ton Completed
#232413 04/22/2007 7:48 PM
Quote
I usually leave the rubber bands on them until I've got the springs installed, and then cut them off.
