| | | Forums66 Topics128,162 Posts1,057,056 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23213 09/11/2002 11:07 PM | Joined: Feb 2002 Posts: 7 Member | | Member Joined: Feb 2002 Posts: 7 | will it be hard to swith the hubs from 6 lug to 5 lug? Will any GM hub work?? What's a good price for a 5 lug hub(used)? Thanks for your ideas.......... AND KEEP UP THE GREAT FORUMS :confused:
53 delux 5 window BLUHEAD | | |
#23214 09/12/2002 5:06 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I have not had any experience with changing the two.I figured G.L.Perry would have jumped on this one. Have you checked any reference books on this interchange?
#23215 09/12/2002 6:36 AM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | GR8TIRES B-I-L says no problem as long as hubs have same dimen. I ask same question when I 1st got my 52because I now have 6 lug on front 5 on rear [came this way from po] I fort. have another 6lug rear to install prob.next month waiting on snakes to go in for their annual nap | | |
#23216 09/12/2002 9:15 AM | Joined: Jun 2002 Posts: 96 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 96 | There's a topic below that raises similar questions. :"redrilling brake drums" Hope this is of some help.
Send David Hicks home - now! "Better to be wrong and kill no one then right with mass graves" Albert Camus
#23217 09/15/2002 12:09 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | If I'm not mistaken, I think that there is a brake drum that will fit right on your existing spindles and rear that is 5 lugger.
Jim Carter knows about this and he's the one that tipped me off to it. | | |
#23218 09/16/2002 5:16 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Used front hubs from '54 Chevy car on my '56 3100. Worked slick. | | |
