2 members (78buckshot, 1 invisible), 390 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
#23213 09/11/2002 11:07 PM
will it be hard to swith the hubs from 6 lug to 5 lug? Will any GM hub work?? What's a good price for a 5 lug hub(used)?
Thanks for your ideas.......... AND KEEP UP THE GREAT FORUMS :confused:
53 delux 5 window BLUHEAD
#23214 09/12/2002 5:06 AM
I have not had any experience with changing the two.I figured G.L.Perry would have jumped on this one.
Have you checked any reference books on this interchange?
#23215 09/12/2002 6:36 AM
GR8TIRES B-I-L says no problem as long as hubs have same dimen. I ask same question when I 1st got my 52because I now have 6 lug on front 5 on rear [came this way from po] I fort. have another 6lug rear to install prob.next month waiting on snakes to go in for their annual nap
#23216 09/12/2002 9:15 AM
There's a topic below that raises similar questions. :"redrilling brake drums" Hope this is of some help.
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
#23217 09/15/2002 12:09 PM
If I'm not mistaken, I think that there is a brake drum that will fit right on your existing spindles and rear that is 5 lugger.
Jim Carter knows about this and he's the one that tipped me off to it.
#23218 09/16/2002 5:16 PM
Used front hubs from '54 Chevy car on my '56 3100. Worked slick.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
