5 members (TPR57C, Bill Hanlon, Samantha, TooMany2count, 1 invisible), 149 guests, and 3 robots.
Topics128,186
Posts1,057,315
Members48,469
Junior Member
Junior Member
Has anybody ever hooked up an air conditioner pump to there 235?? If so where did you bolt the brackets on too etc? I might have to use 2 of the head bolts for the bracket..is this recommnded? Any info or pics would help!! It's not going to be used for a/c but i am using it for an air compressor pump for my air bag suspension. Thanks smile
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
Junior Member
Junior Member
oh ya and how should i hook the belt up to this?? Just off the fan (if i use a double pully on it) :confused: Or should it go around the harmonic balancer and fan pulley?? :confused: or???
Use electric compressor, forget this thought entirely.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Junior Member
Junior Member
That's what i have now and it "blows" haha. Actaully it does not blow enough. I want to use a a/c compressor i already have it and it should fill my tank in about 30-60 seconds. I don't want to buy a bigger electic one for $300 when i have a FREE york a/c pump that will be mush faster and less quiet than an electric one. smile
Check with some of the vendors. I know they make a bracket to mount an A/C compressor on a 235 (kind of pricey though). Patrick's of Arizona is a good place to start. This setup mounts the compressor high on the engine above the alternator and does not require you to find a double groove balancer or fan pulley.
Steve
55 1st Series 3/4 ton
I don't know of any companies that sell a york bracket for a 235. Kilby Enterprises has loads of good info on yorks, though, so you might contact them. I ran mine of the PTO, which works fine, but you have to be stopped to engage the PTO. Running it off the engine is definately a better option, so you can have air on the fly.
"If the women don't find ya handsome, they should at least find ya handy!"
1961 Apache 20 4x4
http://community.webshots.com/album/97352016vHsKNP
