| | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | thinking of buying a bunch of rebuild parts for my front end but how do i tell what type i need? 1`/2 ton 3/4 ton etc etc?? truck is 49 swb 3100 badges 6 stud wheels | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you have a 1/2T [3100], so parts listed either of those ways is what you want, parts listed seperate for 3/4T [3600] won't fit yours
Bill | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | thanks bill how do you know its a 1/2? maybe its the wrong hood?? (badges) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | An educated guess - yes, many 3/4 and 1/2 ton parts might have been switched:
- short wheel base - 3100 - 6 lug wheels (1/2 ton parts will work)
Do you have an ID plate between the hinges on the driver's door post? There is a code on there that will help.
Tim | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | there is a plate tim yes but i cant get to it at the moment but i recall it had 4600lb written on it?? yes short wheel base hood has 3100 on it yes 6 stud chrome grill hood ornament chrome bumpers | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | If the front axle was a 3/4 or 1 ton, then it would have 8 stud wheels. As yours has 6, it is a 1/2 ton.
Could someone have taken an 8 3/4 ton front axle, drilled new holes for 6 lugs on the hub, and mounted a 6 lug drum and wheel? Possible, but not likely and why would some one whant to do this? | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | hahaha great thanks guys now i know il go order some 1/2 ton parts | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | |
