| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | the inside of the bed on my 51 is pretty rough so i would like to hide it does anyone make a bed cover for a 51 3100? :confused: | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Pushrod, I'm sure someone does, but then you have to ask, whether or not you want holes in your truck for the required snaps? On my previously owned 52, the prior owner made his own. It covered up the "shot" bedwood very nicely. To Boot, it was fairly cheap to make. He built a frame (bed height) with an upright in each corner. Then he placed a sheet of plywood on top of the frame. Covered that, glueing some 1/4 (or so) foam on top, then covered the foam with vinyl. The whole unit sat in the bed of the truck, covering up the ugly bed, yet was easily removed, if and when I wanted to haul anything. I think I may have some pictures around, if it would be of any interest to you. There's one small one kinda showing what I'm talking about at the bottom of the gallery page. http://www.stovebolt.com/gallery/coulter_eric_1952.htm | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Joker beat me to it! I've seen the silver truck with the purple flames up close, Gaylord's makes fine products. Unfortunatly, they don't have anything for longbed trucks that are that old. You might check out Checker Products, too. They'll custom make covers in any length. http://www.checkerpro.com/
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | pretty sure classic truck shop orange do covers | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i would like to have one for my 54 like the one i saw on a newer truck which was in sections so i could take it off and store in the bed if i had to haul something tall. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | I built a cover for my 55-2 out of 3/4 plywood two hinge's at front and used a bed rail wire weld to side of bed for the plywood to lay on••• it will bow over time i found out ha (Like i should have knew that)!! put a support side to side on the back 1/3 and a partition with two doors that swing out to each side and a latch to keep them closed then i can put some thing long in the bed if need be and other wise closed off and put ice chest tool box what ever in the very back with a lid ......i used a piano hinge for the back cover . used carpet foam no need to glue it just pull the vinyl tight and stapel it . put wood sealer over the plywood the wife i just redone the back part.. better this time it got sealer and paint!! ..put drawer pulls on to lift with the front 2/3 is heavy .. i want my cover fastened down because i roll it on down the highway . | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've used a company called "Checker" for their "Checkmate" soft bed cover. Sent them the dimensions and they fabricated the frame to fit my specific bed. You assemble it. All the components are included, their service was great and the cost was under $200. Obviously you aren't going to get Gaylord quality for that low price, but it's a good alternative to the higher priced units and it's custom-made to fit your specific application. Hope this helps.
Dave | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | thanks for all the help guy's,,,ron | | |
