2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#22980 05/09/2005 12:48 AM
Junior Member
Junior Member
I just started to rebuild my 61 chevy pickup and noticed that there was a large amount of water/coolant in the oil. I took the head of and the gasket looked fine is there anyother poss other than a cracked block it is a 235. Is there antthing else to look at in the head before I take it to a machine shop. thanks
#22981 05/09/2005 2:06 AM
Make sure you have the shop Magnaflux it (check for cracks)before spending any money on it. It will find cracks that you could easily miss with the naked eye. It costs a few bucks, but it's good piece of mind, especially when you already have a "coolant in the oil" problem.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#22982 05/09/2005 2:59 PM
Did you put a new head gasket on and reinstall the head? You might do that before digging deeper.
