7 members (TexasJim50, 1955 1 Series, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible),
54
0
Mod | | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | my cousin has a 46 3/4 ton, with a 4 speed and heavy 3/4 ton rear end. he told me it has a high/low side on the trans, and on the rear end it is a two speed. did these exist or is this a jimmy rig job over the years? 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It may have a "Brownie box" mounted aft of the transmission to give it a high/low option. I don't think there was ever a 2-speed rear-end offered in a ¾-ton. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | oh well this is what he told me. but i can't believe everything my cousin says anyway 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | is that brownie box like an overdrive to give you your high side, or does it make your trans even lower, so when you hav it in high side it is like normal 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's probably a switch or lever up on the shifter that resembles the two-speed switch but it's for reverse gear. He may not know what is what if this truck doesn't drive yet, Scott | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Brownies came in several configurations. Some were low/lower, some low/high, some normal/OD. | | |
