9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
#229629 03/18/2007 6:48 AM
Started on suicide doors.....
"If it ain't broke, I haven't gotten ahold of it yet!"
'51 Chevy 1/2 Ton 5 window
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
One VERY understanding wife
http://community.webshots.com/user/51rustbucket
#229630 03/18/2007 6:57 AM
Sorry, I hit the add reply by mistake. It's still St Patty's day ya know hehehehehe! (dang jack & cokes)
Seriously though, check out page two of my web shots & tell me what cha think
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229631 03/18/2007 9:33 AM
Wild!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#229632 03/18/2007 1:48 PM
51, i wish you hadn't posted this, it is what i have wanted to do. i always have wanted something with suicide doors. my truck is in the body shop now having the body panels redone. i have to pay for the work and i am really far into this. i think i will wait til everything si straightened the thik about the doors. looking good. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#229633 03/18/2007 3:27 PM
Very good! I have always liked suicide doors! Did you find they very complicated to do?
#229635 03/18/2007 6:04 PM
I've never understood what the seeming obsession is with suicide doors. I don't see that they look any different closed and can't see any advantage to them. Can anyone explain? I have a car with them, and people come up and say, "Wow, suicide doors!" and I think,"So?"
#229636 03/18/2007 6:06 PM
Junior Member
Junior Member
Speaking of doors, I posted this in The Doors under Clinics but stuff seems to get overlooked there sometimes.
I'm thinking about using a set of 1950 doors on my 1954 chevy. Can anyone advise me of what problems I will run into?
#229637 03/18/2007 7:25 PM
we b old , I know exactly what you mean. I get that twinge of jealousy/envy whenever I see em.
Coach-frank, They're really not hard to do, they just redefine the old "Measure twice cut once." I think the hardest part is that I quit smoking going on about 2weeks now. Hopefully that explains all the cussin and throwin stuff!
Windows?............ I knew I forgot something.......
The trickiest part is you can only get about 3/4" deep in the door before you hit the window track. I still have to make an 'S' bend on the top hinge to get the door to swing out 90 degrees(without the back of the door hitting the cab) and close properly.
Baldy, What are your suicide doors on? Where I'm from, you only see suicide doors on high-dollar rods. I wonder if it's because most shops charge an arm & a leg for em, or they have more taste than I do?. To each his own, it took me about a month to convince my wife to let me do them she thinks they would ruin the truck. Oh well, she doesn't have to ride in it .... :blat:
Smitty , just as an idea, LMC lists doors from '47 - '50 and '52 - 55. I'm not certain but the only difference should be w/or w/out vent windows.
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229638 03/18/2007 8:44 PM
Hey Smitty. I did it with no problems. Hey rust bucket...sweet doors.
1951 3100
#229639 03/18/2007 9:03 PM
the shop i use wanted 2500.00 to do a car but didn't really want to do it. because of the price i think the guy did not do it. i havn't talked to him about because i would like to get it back and drive it for awhile. i has been one shop or another since last june. i have even toyed with idea of getting a car with the doors, probably a mid 30's chrysler product. but i then think the money spent on the new car could make the truck first rate. ron
2017 Buick Encore
See more pix
#229640 03/18/2007 10:13 PM
smitty's54 the differece should be your vent windows on the doors, other than the one piece windshield i believe the cab is the same as a 47-53.
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#229641 03/19/2007 12:30 AM
The rear doors on my 33 Chevy sedan are front opening, as have been the back doors of several cars I've owned, including a 39 Packard hearse and a 46 F@rd. My two 1952 MGTDs were the only ones with front opening front doors. I often had to push start one of them, and found it hard to get in quick enough to pop the clutch, so I usually jumped over the door to get in.
#229642 03/19/2007 3:53 AM
Baldy, I actually thought of suiciding the back doors of my wagon kind of like the old lincolns. I got a four door so I could tote my kids around & My only worry is that I just know one of em will forget to deadbolt a door. eek
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229643 03/19/2007 4:39 AM
Here's a couple things you might give thought to because you obviously have the ability to do them. These old trucks used a windlace around the door opening which cuts wind noise to about 55mph but no faster, you might make provision for a gasket type seal since the latch opening is gone (I'm sure your using bear claw). The bottom is the challange. A switch that's open when the doors open and closed when door is COMPLETELY closed and interlocked into the ignition is a safety touch, especially if kids may ride. In cases of close window channel clearance (not yours) the strap can be mounted to the doors inner surface and then a sculptered upholstery panel used. The bumps can be incorporated into the sculptered design. We're doing a 31 A coupe now and it's doors are really skinny so this might be imperative. Good luck and yours looks great.
Evan
#229644 03/19/2007 5:08 AM
Good idea, what type of seal would you reccomend? And yes, I'm using bear claw medium latches. I guess I was just planning on ordering the original style seals. I want to say there is one seal for the door and one for the cab plus the windlace?
I think Autoloc sells the automatic deadbolts, they aren't cheap but they're a heck of a lot cheaper than a door blowing open a speed! I figured I'd order them when I get the rest of poppers and electronics.
I know what you mean, were doing a ground up on a '35 chevy coupe at work. These are probably just a hair thicker than an A's doors.We went with the power windows that have their own track which gave us just enough room to get the strap flush with the inner panel.
Thanks for the advice grin
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229645 03/19/2007 11:48 PM
Robin, thanks for the info. Yours looks good, like the 'vette wheels too.
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229646 03/20/2007 6:50 AM
My uncle had a Lincoln Continental. Big as a whale. I loved those suicide doors. No one else had them. Too cool. Don't you just love all that old iron. Remember all that chrome?
#229647 03/20/2007 7:46 PM
I know what you mean. The only reason we have the '01 Monte is because the wife got tired of driving my '72 Nova. Divorce was too expensive.... grin sooooo we got her a new car.
I would rather spend my time polishing chrome. I hate front wheel drive, puny fuel injected motors, ABS brakes, Air bags & all that junk.
Give me old iron with a fire-breathin, carbeurated gas guzzlin small block, crank windows and 'god I hope it stops' brakes. I prefer my 'air bag' in the passenger seat (here comes the hate mail now!) There now I have finished my rant. wink
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229648 03/21/2007 12:32 AM
can i put suicide doors on my 64 with out much prob ? keep in mind when i say not much prob im 13 fixen 2 run 14 friday
LEWIS
#229649 03/21/2007 5:04 AM
Rebel, they're not that hard if you're handy with a die grinder and mig welder. Your best bet is to google 'suicide doors' as much as possible, look at Robin58's and my pics then just start cuttin and weldin. Ask all the questions you need to, you'll see its not hard even for a young'n!
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229650 03/21/2007 3:15 PM
Thats a pretty informative site. I got sidetracked with some family stuff and have yet to get back to finishing mine.
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229651 03/22/2007 2:16 AM
Rust bucket, what we usually do is to give the dimensions of the channel we want the w/s for to Metro Molded Rubber Products in Minneapolis and they invariably have something with the right dimension in stock. They aren't a stocker and re-seller like many suppliers, they actually have the dies and extrude their own. I think Steele might also but the others all come in Taiwan packages. Metros catalog has actual size cross section pics that can put you real close. Will get their ph.# tomorrow if my brain doesn't go dead the minute I walk through the door.
Evan
#229652 03/22/2007 2:44 AM
Thanks Evan, do you recommend this single gasket over the double factory seals. If you get a chance is there anyway you could get a picture of a car with this seal done? I would kinda like to see what the finished product looks like.
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#229653 03/23/2007 11:26 AM
Scott, will be glad to take a few shots but right now it's unfinished. The A doors overlap the body about a 1/2", kinda like shingles on a roof. We used the door as a guide and cut around it with a plasma torch which gave 3/16 clearance for door gap. Then a 1/2x1/2 angle formed from 18g cold roll was migged in. I went to the Metro Molded catalog (http://metrommp.com/) ph 800-878-2237, and clicked onto "extrusions". I think I will use the 1/2x1/2 seal that has the flap sticking off of one corner, much like door seals in the 50's & 60's. Like all from scratch projects everything is in flux and adjustments necessary but, that looks good right now. Will snap a pic and put it on my photobucket site with the "as is" progress.
Evan
#229654 03/23/2007 4:05 PM
Heck, you could just leave the door overlapping and that would eliminate the need for the seal right? Just be sure to use the proper size nails when securing the door to the body. grin
I appreciate it, just let me know when you get around to it.
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
