3 members (stlcardinalsguy, Woodcmiami, Guitplayer), 79 guests, and 2 robots.
Topics128,091
Posts1,056,034
Members48,433
#229570 03/17/2007 4:09 PM
Looked at a '64 stepside locally the other day and where the heater/defrost controls are it just had a plate with a pull knob in the middle of it.Thiught this was some homemade job until I just seen a couple on ebay with the same thing.I figure it's just pull out the knob and you have 1 speed and it comes from the defrost and heater.Is this correct?
Gary
Current project . . . 1960 LB stepide Chevy
#229571 03/17/2007 7:27 PM
your '60 should be different. Mine has 4 levers,fan, defrost, air control(not ac) heat temp.
#229572 03/17/2007 7:46 PM
The "THRIFT AIR HEATER" has a single knob. Pull the knob out to open a door in the heater assembly, and turn the knob clockwise to turn on the blower motor. There should be three speeds for the blower fan. There also is a lever for "HEAT" and "DEFROST" on the heater assembly below the dash on the passenger side.
Most of the 1960-1966 trucks have this type of heater.
#229573 03/17/2007 8:45 PM
that is what mine is in my 64. on mine to pull the knob out makes the bowden cable open the defrost, pushed in activates the heater. three speed fan. hr
#229574 03/17/2007 9:54 PM
My 66 has that. It was the standard option heater. Turn the knob to the right for fan speed, there are 3 of them. Pull it out for temperature and the defroster is a handle under the dash passenger side that says "DEFROST" with an arrow pointing up and "ON" next to it.
Personally, I like it since there is only one knob to mess with compared to 3/4 lever setup.
#229575 03/19/2007 6:41 PM
That's odd, my 61 just has two levers. I have a blower and direction lever. One controls the blower and the other is for heat or defrost. I have never seen the knob type, but it sounds interesting.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#229576 03/20/2007 12:24 PM
Thanks guys.That explains everything.
