1 members (Opelika Tom), 115 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
#228701 03/05/2007 7:07 AM
i stared a post questioning if you can swap the pumkins on the 3/4 ton 47-53's, i was doing some reading on it, and my question is if you can swap these pumkins out with a 67-72 3/4 ton, can you find a 4x4 3/4 with a locker and just puit a locker in the rear end of the 47-53 using stock pumkin, or are these totally different?
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#228702 03/05/2007 5:52 PM
I think you need the later frame. To install a 4.10 (or rarer, a 3.90) in a pre-62, you need the later carrier. Different internal measurements, I'd guess, so a later locker would need the later carrier.
#228703 03/05/2007 7:54 PM
First regarding carrier. I've heard (never tried myself) that the 4.10 gear can fit any carrier. However, nobody sells the gears alone, so why not buy the whole pumpkin and put it in, then no worry.
They used to sell the 3.90 gears, but I don't think they've had them available for years. You did need the later carrier for these gears.
They did make a 17 spline "locker" for these pumpkins. They are NOT common. However, you can buy a detroit locker built for the 14 bolt GM axle, and buy some correct length 14 bolt axle shafts (from Patricks for instance) and install both of them in this axle.
The above is a REALLY STRONG setup. More like a 1 1/2 ton axle. The 4x4 guys been doing this for a while, cause it's strong, it's a full floater, it's light, and it's got pretty decent ground clearance. Only thing they really need is the 5.13 gear from the 1 ton axle. Fairly rare.
