5 members (Wheelie, Gdads51, klhansen, greenie-reddy, 1 invisible), 87 guests, and 3 robots.
Topics128,036
Posts1,055,452
Members48,422
#228610 03/04/2007 5:24 PM
Apprentice
Apprentice
Oh wise ones,
I just received my new brake lines from inlinetube. First, they look great. Second, I have never done a complete "re-line". Anyone, know where I can get a diagram? I really don't want to goof this one up. It came with 6 pieces and I have the 3 hoses. Also bought brand new clips. Any suggestions would be helpful. Thanks!
What have I gotten myself into?
58 Apache
65 C10
76 Silverado 4x4
03 2500 HD Duramax
http://s223.photobucket.com/albums/dd10/jbreen33/
#228611 03/04/2007 5:56 PM
Riding in the Passing Lane
If you havn,t already pulled the old ones you could make a diagram or take photo,s. Be shure & use tubeing wrenches & back up the fitting before tightening.
1972 Chevy c10 Cheyenne Super
#228612 03/04/2007 11:11 PM
Classic Performance Products has a tech help page. It might help you.
http://www.classicperform.com/tech.htm
~Jim
#228613 03/05/2007 5:21 AM
Just replace them one at a time and you shouldn't have any problems.
The hoses should be labeled as to where they go.
#228614 03/05/2007 6:14 PM
Apprentice
Apprentice
OK...Thanks for the help...What I pulled off of the truck doesn't even resemble what I got from Inline.
Let me see if I have this figured out. The long line connects to the M/C. Then split off to the driver rear with a T to go accross to the passenger rear another T and a hose...then head up to passenger front connect a hose and then to drive front connect to a hose. Kinda ...maybe right?
58 Apache
65 C10
76 Silverado 4x4
03 2500 HD Duramax
#228615 03/05/2007 6:54 PM
Just did my 4t6 recently and I had had a total of seven lines. One from MC to brass tee. Off front tee to another 3 way brass connector. One to right front rubber hose one to left rubber hose. Off brass tee to rear of truck connected to rubber hose to rear end brass tee. On rear it split to both wheel cylinders. I made my own lines by using the old ones. I removed after and clearcoated. I included pictures below if I made no sense. Could take more if needed. Hope this helps
Dan
http://rides.webshots.com/photo/2141598560071274430agewIk
#228616 03/06/2007 12:09 AM
I just finished duplicating the original lines on my ’50. I might add after looking at Dan's picture of the front divider that the line leading to it from the center divider should have about a 2" expansion kick up in it allow for adjustment of the length and thermal expansion. In fact all brake lines should have some sort of expansion compensation.
This is an exact copy or an original factory line; http://rides.webshots.com/photo/2062157930098611668OdKgrK
I had to make up these lines while the truck was still assembled so the angle of the picture is a little cramped but I think you can get the idea.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#228617 03/06/2007 1:44 AM
Apprentice
Apprentice
Thanks to everyone for your help and suggestions. I think I have it figured out.
58 Apache
65 C10
76 Silverado 4x4
03 2500 HD Duramax
