8 members (carbking, Gdads51, Wally / Montana, klhansen, NJC, 2-Ton, 55shaker, Joe H),
46
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | What for, and or when would you use the throttle knob on ( mine is a 1960 apache)truck. The choke works the throttle cable knob comes off so I never use it . Is it to warm up or start truck ? Or like a cruise control. Can I replace the cable with new knob and will it last or just break again?
Thanks for the help Ken
Oh ya is LMC good to buy, say rear bumper & crome mirrors? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ken, the throttle could be used for warm up, but was most useful to maintain an RPM for granny gear chugging in the fields or running a PTO when stationary .... NOT recommended as a "cruise control" if you value your life
if the replacement is decent quality it should work fine, tho I didn't know the 60's still had them from the factory .... can't say about LMC
Bill | | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | I have one on my 50 truck that I was thinking of turning into a light switch or perhaps a cover for a cigarette lighter socket.
'50 Chevy truck 1/2 ton
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I always have figured that when you had the starter button on the floor, you needed three feet or a throttle button to get a cold motor started. One foot on the clutch, one on the starter button, one hand for the choke, one for the throttle knob so the motor doesn't race away. When they went over to keyed starters, so many were used to seeing the throttle knob on the dash - and they had found all these other uses for it - so it took some years to phase out the throttle knob. But the throttle knob must have disappeared in the early 60s, so yours would be one of the last years with one I would guess... It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Oct 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 62 | Ken1960- is your truck an auto or stick? I have a 1963 c20-4speed that doesn't have a throttle knob. I have seen this on '60 or '61. They phased it out pretty early in the '60's is my guess, darn shame too. Maybe they kept it on the big bolts though :confused: , I just don't know. On my '63 to the left of steering wheel is choke, wipers, and lights, no throttle I would so try to jimmy rig/replace the throtle control if you have the time, just for the novelty factor. If you have it, you will use it, would be great for jump starting other vehicles, eh?!?!?!?!!
I see a GM truck in your future!
| | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | don't know how long they kept the throttle feature but i still have it on my 50. have used it only to keep it at a higher rpm for diagnostic purposes. the truck doesn't see a lot of "granny" gear work since it's retirement.
norm84, give up the cigarettes and leave it as a throttle. you'll live longer and it will maintain it's value...by the way, how is chattanooga? been too many years since i walked the streets there. nice place and i loved the history of the area. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I do know a guy that has a '72 C20 that has a throttle knob in it. Stangely, it's also an automatic. Like red58 said, it's mainly for PTO work. I do use mine during warm up to keep the rpm up, but not for a cruise control. That's not only dangerous, but illeagal in most states.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I use mine for warming the engine up or diagnostic purposes. I joke about it being an early form of cruise control, but I've never used it as such. Keep it. You might need it someday, and it doesn't hurt to have a functioning hand throttle.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Jan 2007 Posts: 30 New Guy | | New Guy Joined: Jan 2007 Posts: 30 | My 1961 also has this knob on the dash but it is not connected. Would definitely like to keep it as I always get questions about it!
Where does this thing connect? Is there a diagram somewhere? I cant seem to find it in the 1960 shop manual. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have to disagree with the above assessment regarding using the hand throttle for a "cruise control". My Harley has a thumb screw on the throttle that will hold in position, I have used it as a cruise control for many years without problem, but of course only on the open road. Proper use of the hand throttle under the same circumstances would be useful, but of course you need to be on constant alert to traffic ahead. I just bought a new reproduction throttle cable for my GMC 100 and will be using it on long trips on the freeway. Happy 'bolting to all however you use or not use your hand throttle. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The hand throttle has a bracket on the carb, and the center "wire" threads through the hole in the pushrod that goes from the bellcrank to the carb. It has a little screw clamp that holds it on. Somebody has a picture of it on the net somewhere.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | My 69 has a factory hand throttle in it, and it is an automatic. They were very common until about 72 or so when the emissions controls started up. | | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | Ken, like you I have a functioning choke which sure comes in handy on a cool day. I'm figuring now how exactly I'm going to hook up my throttle cable to my old Edelbrock carb. I'll use it to raise the RPM during warm up ONLY, so I don't have to push on the accelerator for 10 minutes on a cold day. I would never mess with it while driving. | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | Over the weekend I got up..... ?Then I broke out the 1960 Ch. Truck operators manuel .. and I Quote HAND THROTTLE CONTROL Pulling out on the knob opens the carburetor throttle to provide a uniform ( constant until knob is pulled further, or pushed in to any position) engine speed above the idle setting. It is generally advisable to pull the hand throttle control out slightly when starting the engine especially if the engine has a tendency to stall a time or two after starting."
Also my tranny is four on the floor .
Ken | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | I can look further into it as to how it is hooked up if anyone needs to know . It is working if I use plyers as the knob comes off. I checked it out over the weekend. You can see the accel. pedal moving .
Ken | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I have my RPM set so low, ~300, that I use mine to keep the revs up both when cold and also when stuck in traffic to keep the fan and water pump spinning fast enough to cool. It's also handy for starting out on a hill. | | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | Anybody have a picture of how to hook up the throttle cable on a 51 with the stock one barrel? My choke cable works great but the throttle cable has always been broken, never really knew what it was used for until I read this thread! | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I would also like more info on how the cable attaches. I have a 52 with a 56 235. According to the resources I have the cable hooks to a bracket on the carb. and bypasses everything else.then it hooks to a bracket on the shaft that operates the carb. It seems to me that running the cable through the hole on the shaft that hooks to the carb would be real unsafe. Constant rubbing on the wire to the throttle control would wear it out. Using the wire to retain the shaft would mean no throttle if it breaks. According to the pictures I have the bracket rides up and down on the control wire, with a cable stop on said wire. If the wire breaks the washer and cotter key on the shaft to carb is still functional. That way the if the throttle control fails the pedal/shaft/carb assembly is intact and able to function. Just my 2 cents worth. Jimmie. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Constant rubbing on the wire to the throttle control would wear it out. How many have you seen wear out? | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The factory installation of the hand throttle cable connection to the carburetor is the cable sheath (outer cable) is threaded thru the choke, throttle bracket and the wire is fed through the hole in the linkage that is fitted to the carburetor. There is a small barrel shaped fitting with a hole for the wire and a set screw on the end to hold the wire in place. This allows the hand throttle to be used and still the foot feed works up and down on the wire of the hand throttle. I worked on the engine line at the Van Nuys Chevrolet assembly plant so I saw a bunch of these before they came off the assembly line. | | | | | Joined: Sep 2006 Posts: 18 Junior Member | | Junior Member Joined: Sep 2006 Posts: 18 | hi , my 59 still has the original and working hand throttle and knob connected to carb , just ask and i will send a pic for anyone, cheers , stevie-t | | | | | Joined: Sep 2006 Posts: 18 Junior Member | | Junior Member Joined: Sep 2006 Posts: 18 | hi , there is a pic of dash , click on description, if you need a pic from carb side, just ask, as it is connected and working as new | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Stevie-t:
That truck is a wonderful resource for those of us with Task Force trucks who want to restore to original. It really helped me to see the exact paint scheme for the interior. Even though mine is a 58 Fleetside, the more pictures the better. Do you have an account with one of the free picture hosting websites that you wouldn't mind posting the address to?
Sorry, I kinda' hijacked this thread.
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Running a Rochester, the bracket as shown in Laroke's link is dead-on. However, I found that the bracket doesn't work with a Carter. For the throttle cable to align with the linkage movement axis, there needs to be an extension, approximately 1.5" toward the firewall. I made an extension out of 3/16" thick flat bar and attach it to the carb. I attach the choke cable bracket on top of the extension at the carb body, then attach the throttle cable to the extension on the opposite end. This is the only way I could figure to get the linkage to move without binding the cable.
I can't believe I'm the first to experience/observe this. Any other solutions?
Lumbergh- Stevie-t's truck is a time capsule, and a beautiful one at that. I echo your comments. No hijack, no foul.
Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Nothing like ole Stovebolters! Almost 30 replies in a discussion of a "white knob" on the dash. LOL :hammering:
~Jim
