1 members (homer52), 88 guests, and 3 robots.
Topics128,127
Posts1,056,678
Members48,452
#228412 03/02/2007 1:34 AM
I am looking a picking up a new rear axle for my 1948 GMC. I found one out of a 1997 2500 4x4 HD but I would like to know the gear ratio befor I buy it. I have the production date motor size and vin. Is there anywhere I can look this up?
Thanks..
If you have the VIN of the doner, you can check with any GM dealer to find out the equipment that was on it. Any particular reason you want to use that diff? I would think that it would be awfull wide for a '48, especially if you use the 4x4 version.
Bill Burmeister
One of the reasons that diff appealed to me is the axle ends look almost identicle to what is on it. I measured the dust backing plates and they are the exact same distance appart (52") I did not get the wheels off of it today to see if the distance between wheel mounting surfaces are the same. I will check that tommorow.
Thanks for the info Bill.
the rear end should be close to the same width
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
Junior Member
Junior Member
3.73 or 4.10
1957 3600 line built Napco
1957 6400 350 and hoist
1949 3600 14 year project
Lots of other jeeps,chevs, Yota and even a F**D
