2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Did a search here but not much on this subject. I'd like to rebuild/replace my funky old front and rear leafs so I went to a very old and reputable spring shop in my area, Deaver Springs. (He has helped me in the past adding a leaf to my stock F150 to improve my load carrying capacity and he did a great job. And like I said, he has a very good rep. in this area) Told him about my '57 3600 and he said no problem. If I bring them in he can take them apart, fix 'em, rebuild or replace them, supply me with all new u-bolts, shakles, pins (depending on condition of the old ones). He can add a leaf to the rears to improve my load carrying capacity too. Then I said, how much are we looking at? And he said about $1200. Does this sound reasonable or should I look at other options? | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I spent $1700 (CAD) locally on new springs (not rebuilt or rearched...new), shackels, poly bushings, u bolts front and back. I thought I got ripped off, but I have heard different prices from everyone so unsure here.
Good Luck. | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | St. Louis Spring did me right. They re-arched my springs, rebuilt the pack, new pins and bushings, added a leaf. I think it was around $200 for the job. These were 2" wide springs I believe
I had a set of auxiliary spring packs made for my rear. 5 leafs each, 2 1/2" wide, about 3 1/2' long. Made at some place in Dayton Ohio I believe (before I found out about St. Louis spring) and it cost me a little over $600 plus shipping.
St. Louis Spring did me right! | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | All four springs gone through with new bushings, and new mains on the front were $450 or so here in MPLS/St.Paul. The truck sits level and the spring company that did the work has been around forever.. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | in kansas city i was going to revamp/rearch my springs on my 63 k10, and i was looking at 150.00 a corner- 600.00, and thats me taking them in, and them not giving me u-bolts, give kc spring a try. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Just to be sure what I have is correct for this vehicle, my fronts are 22" from front to center, 22" from rear to center and 2" wide with 7 leafs. The rears are Approx 25 1/2" front to center, 26 1/2 rear to center, 2" wide with 14 leafs. Does anyone know if this is correct for '57, 3/4 ton? I want to be sure before I call out to various suppliers for pricing. | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | You might call Benz Spring in Portland Oregon. They are also very old...Been in business since the 20's, I think. I contacted Deaver about getting all new springs for my 55.1 3600. They wanted $1250.00 plus tax. I called Benz Spring, after a buddy said he had a good experience, and they quoted me $560 out the door for (4) complete brand new spring packs with new bushings installed. Even with UPS, it's still a helluva lot better than Deaver.
1956 GMC 100 NAPCO Deluxe 1955.1 Chevy 3600 NAPCO 1954 Chevy 3600 NAPCO
| | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I bought a pair of new front springs and u-bolts for my 55.2 3/4 ton in January from Benz Spring in Portland.
I called on Friday morning and UPS dropped them on my porch on Monday afternoon. $324.65 complete.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Update: Turns out the springs I had on this thing had been built up dramatically. The rears normally have only 9 or 10 leaves. Mine had 14. Fronts normally have 6. Mine had 7. No wonder I was able to carry over 4,000 lbs Price I was quoted locally ("about" $1200)was for standard set of springs. Benz Spring in Oregon has hooked me up with replacements for what I had, plus new U-bolts and shakles, plus shipping to Southern California for $1,091 complete. They are building them now. I will let y'all know how it all works out. BTW, if anyone would like to buy my old springs, they could probably be easily taken apart, cleaned up, friction discs and bushings installed and be perfectly fine. I will be posting in the stuff for sale section. Take care and brush your hair... | | |
