4 members (1955 1 Series, Barney1951, Otto Skorzeny, 1 invisible), 44 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#227706 02/20/2007 5:42 AM
Looking at the original front leaf springs from my '50 3100. The passenger side has a caster shim on it the drivers doesn't.
Is it ok to rebuild the springs without shims and just have an alignment shop put the correct ones in once the truck is back on the road?
Bob
1950 Chevrolet 1300
#227707 02/20/2007 6:25 AM
3B Offline
Hy Bob H, yes that is fine, the shim is not part of the spring, the alignment shop will install what is appropriate, hope that helps.
#227708 02/20/2007 7:36 AM
I'm not so sure the average alignment shop around here would have shims for these old trucks. You might want to go to a spring shop and pick up one for the other side before you go. I think I'd just go ahead and install it before I went. I have the same situation on mine, a shim on one side only (?)
#227709 02/20/2007 4:01 PM
Napa also sells them, $2.00 each or close to it. Start with the 2 degree, that should get you pretty close. Joe
#227710 02/21/2007 12:25 AM
Find out where the local delivery guys get their vans done... Lots of straight-axle cube vans out there, so someone knows how to align them.
Good luck.
#227711 02/21/2007 1:35 AM
The problem is that the only currently availible solid axle shims are too wide for the older trucks. The narrowest that I've seen is 2 1/2", the spring seats on the old Chevies is only 2". I suppose you could cut them down, but the way that they're made you'ld probably weaken the shim.
I also question as to why only on one side. Those shims are meant to be used as a pair, and only when the amount of caster change is equal. It's making me think that the axle might be twisted. I'd suggest leaving it out, then have the front end alignment checked at a shop.
Bill Burmeister
#227712 02/21/2007 1:43 AM
Bill,
I too wondered why only one shim. Would 'one in' and 'one out' have enough oink to twist that big forged axle. They surely couldn't have forgotten to put the second one in.
Would the front end shop be trying to compensate for crown in the road...or a lower right shoulder. My '97 Silverado had some weird things done to it in an effort to stop it from wandering...I wonder if it was done on one side only.
Stuart
#227713 02/21/2007 4:08 PM
The Napa shims I bought were made to cut down to the right width. Mine are only 1.75" wide. joe
