8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | Chevy's universal compact spare tire, what bolt patterns will this tire fit on, I am thinking of getting four from the wreckers to roll my 49 around the shop on....any ideas?? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My local farm and fleet store has the car dollies you set your car on to move around. That way you could move it sideways too, unless you plan on going off of the concrete, Scott | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | (Most)Isuzu/Nissan wheels will fit. Brian | | |
#2278 03/14/2005 12:06 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The only compact,(donut)spares I have seen are 4 3/4 5 bolt Chevy car pattern. | | |
#2279 03/14/2005 10:31 PM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | the spare has 10 bolt holes, looks like two 5 bolt patterns, 4 1/2 and 4 3/4, I was hoping with the 10 holes it would fit the 6 bolt pattern
Thanks for the help | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 6 bolt? Not unless you cut some of the studs off.
Fred 52 3600 69 C-10
