2 members (TUTS 59, Leo), 62 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#227627 02/20/2007 1:04 AM
In the center of the art deco dashes on the verticle face under the 5 verticle grooves and above the ash tray there is a horizontal hole that is about 6 inches long by 3/8 inch wide. What is this hole for???
#227628 02/20/2007 1:10 AM
I'm not an expert on the 40-46 dashes, but could it be for a lever that controlled the heater?
Just a guess.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
#227629 02/20/2007 1:11 AM
Lighting of the ignition switch and cable knobs. There should be a light bulb in a socket behind that slot. The light is controlled by the 3 position slide switch under the dash.
To be long remembered as he's cruising in
The Passing Lane
#227630 02/20/2007 1:18 AM
SHAZAAM SHAZAAM SHAZAAM!!! That was fast! I'll have to do some investigating to see if that socket is there!
Thanks Barry!
#227631 02/20/2007 2:34 AM
Thank God for Barry Weeks. When I saw dash hole, I was pretty concerned people had made up a new curse for stovebolters. smile
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#227632 02/20/2007 3:01 AM
grin
#227633 02/20/2007 3:09 AM
I'll admit, I can be a dash hole at times. grin Are you sick of snow yet Bill? Looked like Oswego got covered up until spring.
The Passing Lane
#227634 02/20/2007 4:51 AM
Isnt that called a map light switch?
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#227635 02/20/2007 5:27 AM
It's called a map light switch on a 77 Coupe Deville. grin
Joe smile
#227636 02/20/2007 6:41 PM
Joe if its not a map light switch on a deco too then that n.o.s. switch i got from carter must be for a42 coupe deville :hammering: hmm.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#227637 02/20/2007 7:02 PM
The light bulb is actually mounted in the bracket that reinforces the choke & throttle cable attachment. The switch and light are mentioned in the owner's manual
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#227638 02/20/2007 7:16 PM
#227639 02/21/2007 1:30 AM
Yeah, My book showed the switch, but it didn't show the lamp. My Truck is missing the switch, and the lamp isn't in the socket. I'll have to find one of those 77 cadilac map light switches. Maybe I"ll put a neon tube up there, and where the stainless trim goes... NOT!
#227640 02/21/2007 2:02 AM
Z
Z Offline
I just pulled the slide switch out of my 46 daddy if you want it for yours. Just pm me your info and I will drop it in the mail to you.
Charlie
1946 Chevy Pickip
#227641 02/21/2007 2:58 AM
This is a great site. I apparently know nothing on this subject, but now I know more. Thanks for all the good info.
Photobucket Album
#227642 02/21/2007 4:55 AM
Barry,
I'm sick of snow and the cold. I'll bet you know the cold better than me though. Yesterday it was -30 when I got up for work. Today it was 34. This has been a winter to remember here in Upstate New York.
Bill Schickling
My web page
#227643 02/21/2007 5:45 AM
All you East coasters prolly think us Left coasters are nutz, But I sure wish we had snow here. It's been a pretty dry year so far in Sunny California. I just hope they don't start mentioning the "D" word.
#227644 02/21/2007 6:06 AM
High here in Hurst, just east of Fort Worth, today in the lower 70's. Got a Swap Meet this week-end just north west of Fort Worth at Decatur, Texas. Friday's high should be 69 and Saturday in the 70's. Chance of rain. This is the best it has been for the whole month of February.
Joe smile
#227645 02/21/2007 6:07 AM
...or the "E" word (earthquake) or the "F" word (forest fire) or the... If it ain't one thing, it's another, out there. grin
The Passing Lane
#227646 02/21/2007 6:12 AM
right here in kansas we have the best of both worlds, ice, cold, snow, and negitive temps. - then heat- to much heat, and triple digit heat, and yes the "D" from time to time, its nice in the spring exept the tornados, but fall is nice also today was in the 50's and 4 days ago it was around 2 or 3 and snow
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#227647 02/21/2007 2:05 PM
Bigbadswingdaddy:
A tip for when you install your new dash light. Be careful of the space between the bulb and the back side of the dash. You will see that the bulb socket clips into a bracket held in place by the choke and throttle cable mounts. If this is not assembled correctly there will not be enough space between the bracket and the back of the dash. I had my choke and throttle cables all installed at both the carb. end and the dash before I tried to insert the new light bulb and socket into the bracket, and had to take it all apart to slip in a couple of spacer washers. Not sure if they should have been there in the first place or if the replacement bulb is a different size. All somewhat frustrating while laying on your back with your head wedged under the dash. All the worse as I could have done it all when the dash was laying on the bench.
