11 members (Gdads51, dt235sd, Gray_Ghost, Woodcmiami, Shaffer's1950, Nick in Manitou, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, 1 invisible), 70 guests, and 4 robots.
Topics128,131
Posts1,056,372
Members48,441
i was finishing rebuilding the front axle on ny 1963 gmc k10, i put 1964 chevy axles under instead of 63- i wanted self adjusting brakes, i was alomst done with job and found one of the front hubs were the race sets it chewed up, i am in desprite need of a 64-66 k-10 front hub, does anyone make these or does someone have them for sale all info would be very helpfull thanks mike
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
Try a junkyard or the swap meet section here.
•1952 Chevrolet 3800 pickup
---All pictures---
Is the k10 a 4wd?
I thought the spindles were interchangeable from the later 73-87 trucks, giving you the disc brake upgrade.
What part of the hub is chewed up? The bearing race, or the seat for the bearing race? If the race sits tight in the seat, it should be fine. If the race is loose or wobbles, the hub will need replacement.
i have tried all junkyard in eastern kansas, and have never seen all at swap meet, yes k 10 is 4wd, but the knuckles are inclose unlike the later model they won't fit, we look at useing a k5 blazer one time, but decided to keep original
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
Try this site.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=forum;f=30
it's a pretty good one.
---All pictures---
Junior Member
Junior Member
If you don't find it locally....this guy is 100% trustworthy and a darn nice guy... I just got a steering gearbox from him for my 56 - 3600.
Owens Salvage
Abeliene, Texas ? - I think....
1-800-798-2581
Ask for Bob. He will quote you a price for pulling and shipping the part.
good luck - Kyle
I'm a 6 volt guy in a 12 volt world
thanks kyle, i'll call and see if he's got one, these are hard to find
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
the race is loose and wobbles so i need to replace my hub but i can't find one
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
I had a similar problem with a bearing race loose in the hub. I "peened" the race seat with a punch and a 2 lb hammer. You may be able to snug that race by putting several peens in the seat. When you indent the metal, it pushes some of the metal out to the side, efectively taking up some of the clearence. THIS MAY ONLY BE A TEMPORARY FIX! I never had a problem with my race after doing just this.
I am sure somebody will jump in and correct me if I am telling you to do something dangerous. Hub failures could have serious consequences. This procedure may keep you on the road long enough to find a good hub.
H Online: Content
Peen the race bore to snug the bearing if possible, and install it with some green LocTite. The green stuff is called "Sleeve & Bearing Mount, and it's somewhat thicker than regular LocTite. Be sure the hub and the race are thoroughly degreased with brake cleaner or lacquer thinner, etc. before assembling the hub. Assemble the hub before things cure, and the LocTite will find its way into the loose spots. If you need to disassemble it later, warm it up with a Propane torch and the bond will release.
Mike, Did it work out for you?
no sub65 saved my bacon he had one and i bought it, i wanted to fix it so i can forget about it, and no have to worry about it when i am using 4x4 or going down highway. so i managed to locate one thanks again to sub65
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
Glad to here it worked out!
