1 members (CuzzFuzz),
101
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22745 12/11/2003 6:09 AM | Joined: Oct 2003 Posts: 13 Junior Member | | Junior Member Joined: Oct 2003 Posts: 13 | I'm rebuilding my speedometer. I have a doner and a new needle, but I'm not sure how to take the old needle off. The needle sits on a chrome looking center piece that has to come off, but it looks like it has tabs that have to be spread to get it off. What is the best way to do this? I can't see behind it. I only know what it looks like by the new one.
Thanks | | |
#22746 12/11/2003 4:07 PM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Gently twist the needle as you pull it off. It is only a press fit over the small shaft it is on. | | |
#22747 12/11/2003 6:54 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have found that a gentle twist in the counterclockwise direction , against the stop, while pulling gently will release it easily. For some reason that little bit of torque seems to persuade the tabs to give it up. | | |
