2 members (rfs56trk, Guitplayer), 78 guests, and 0 robots.
Topics128,108
Posts1,056,566
Members48,448
#22745 12/11/2003 6:09 AM
Junior Member
Junior Member
I'm rebuilding my speedometer. I have a doner and a new needle, but I'm not sure how to take the old needle off. The needle sits on a chrome looking center piece that has to come off, but it looks like it has tabs that have to be spread to get it off. What is the best way to do this? I can't see behind it. I only know what it looks like by the new one.
Gently twist the needle as you pull it off. It is only a press fit over the small shaft it is on.
I have found that a gentle twist in the counterclockwise direction , against the stop, while pulling gently will release it easily. For some reason that little bit of torque seems to persuade the tabs to give it up.
1951 1 Ton Completed
