6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#226749 02/09/2007 6:18 AM
Has anyone any experience with a 7" wheel on a stock front end of an AD truck? I would put a radial on it but nothing extremely wide. I found some 16" with a 6 bolt pattern in the scrapyard and they are 7" wide.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#226750 02/09/2007 6:50 AM
i would think they would work, i know a guy who had a 1952 chevy 3100 all stock and had alum. mag rims on his he drove it to work and his boy drove it to high school
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#226751 02/09/2007 11:04 AM
I've always ran 15x7" wheels both with the old straight axle and the Mustang II front end. Worked perfect. If the ones you found look good, get 'em.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#226752 02/09/2007 1:25 PM
They don't work on a 1 Ton, I can tell you that. A normal 6" rim is all a 1 ton will take before there are interference problems. It may sound like splitting hairs here but by 7", I take it that you are talking about inside bead surface, side to side, not the outer lip.
1951 1 Ton Completed
#226753 02/09/2007 1:28 PM
I have run a 15 X 8" rim with 4" backspacing with a 235/70/15 tire on my 54-3100 with stock tie rod ends. Had 5/8-3/4" clearance from ends.
Wound up with the same tire on a 15 X 7 w/4" BS rim and upgraded tie rod ends. Noted 1" clearance. Tire is centered in wheel well and have noted no interference with tie rods ends. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#226754 02/09/2007 3:38 PM
My 1-ton now has 215/85-16' tires on 7" rims. Works fine.
1951 3800
-hotshoe
#226755 02/09/2007 5:15 PM
I
I Offline
7" rim width shouldn't be a problem, but it's all about back space (distance from inside wheel flange to outside edge of rim)
#226756 02/09/2007 5:57 PM
Yes the 7" is bead to bead.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#226757 02/10/2007 1:46 AM
Yes, the backspacing is the key. The 16 x 7" rims that I have have a backspacing that interferes with the tie rods. I think that they are off an 80s Chevy pickup. Now the 16 x 6" rims that I have leave about a 1/4" clearance to the tie rod ends.
