7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible), 153 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
#226473 02/05/2007 11:27 PM
What power steering gear have you guys used. My manual is trashed, so I figure I'll spend the cash to put some power. Thanks Jeremy
1961 k-10
86 c-20
02 duramax
There's a company called REZ Engineering that makes an adapter plate to retro fit the newer (70's era) P/S boxes to the frame. I would assume it should also be a 4X4 box too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I was told it was only for two wheel drive conversions. I guess I need to find their number and ask them.
1961 k-10
86 c-20
02 duramax
62 short step:
I have done a power steering conversion on a few '64-'66 Chevy K10 trucks. I used a conversion kit similar to the REZ Engineering unit, that I fabricate myself, specific to the K10 frame rail contour.
With regards to the gear box, I use a '68-'86 Saginaw, quick ratio, three turn gear box. Pull the gear box, pump, brackets, brackets, hoses, pulleys and hardware from a '68-'86 Chevy truck, equipped with the same engine type as your truck, i.e. V-8 or straight six. Sometime in the 80's the threads on the box, pump and hose changed from SAE to Metric. It doesn't matter which you use unless you have a pump with SAE threads and a box with Metric threads. This can be handled, as well, but it is inconvenient.
In any event, good luck with your project. You can send me a PM for additional information about this conversion.
Tony
Thanks Tony I will pm you when I get home from work. Thanks Jeremy.
1961 k-10
86 c-20
02 duramax
