0 members (), 202 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
I was wondering where the spare tire was kept on a 60 Apache 10 stepside. I don't have a side tire carrier. I don't have a spare tire and when I buy one I'm not sure where to put it. Can they be mounted under the truck?
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
Joe:
Some of '60-'66 trucks with the stepside bed had a spare tire mount on the drivers side rear fender. Some of the '60-'66 trucks with the fleetside bed had a spare tire mount inside the bed forward of the wheel tub on the drivers side. Lastly many of the '60-'66 trucks had a spare tire mount under the bed behind the rear axle. Your '60-'66 Chev/GMC Factory Assembly Manual shows all of these options. Good luck with your project.
Tony
Thanks Tony,
I appreciate the information. I'd like to mount it underneath if possible. I only have a owners manual for the truck, eventually I'll buy more manuals.
Joe
Socket Breaker
Socket Breaker
click on 'under bed tire'
http://new.photos.yahoo.com/woogeroo/albums
The diagram image there is a scan from a LMC parts catalog I believe.
click on:
1965 chevrolet stepside pickup under the bed spare tire setup (images of my actual truck)
http://picasaweb.google.com/woogeroo
I have not yet put my spare under my bed, as I have 'previous owner' issues with the current exhaust setup. Once I get the exhaust setup like I want, then I can put my tire under there.
I hope this helps...
-W
Thanks W,
The pictures helped a lot, you have some nice vehicles.It looks like that's where I'll mount it if possible.
Joe
My 61 fleetside has the spare tire under the bed. It's located towards the end of the bed in the center.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Go to a salvage yard and get a spare tire cable winch from a more modern truck. I know Nissan uses a small compact winch that is granked by some small round stock. Just mount it to a piece of channel iron strattling across the frame rails and you're done,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Socket Breaker
Socket Breaker
Quote
The only one that is mine is my '65 chevy truck.
grin
-W
Socket Breaker
Socket Breaker
Quote
Scott
the full size chevy half ton from late 80's to the 1998 or so had the same winch type part... I bought one from a yard from a 1996 chevy truck... before I found the stock unit for mine. I think they still use that same deal, but I do not know for sure.
My dad's old 1985 s-10 had a similiar deal. I think his newer 2003 s10 has that type part also.
My dad found one(a winch type unit) from a gm minivan he is thinking about using on his '53 chevy truck.
The winch would be easier to use once you get it set up tho', assuming it stays in good working order.
It is all about how correct with your truck you are trying to be I suppose.
are ya good and confused yet cal55?
grin
-W
Thanks for all the good ideas and relpies. I was confused already, sit doesn't really matter. :confused:
Socket Breaker
Socket Breaker
Quote
I felt like that for at least the first year I owned my '65 c10...
haha.
grin
But you are in the right place... with the rest of us truck nuts.
-W
