| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22616 10/17/2003 9:31 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Who's started their engine with the hand crank ? I'd like to start my truck with the hand crank, just for the antique show value, but I don't want to hurt myself. Any help ? | | |
#22617 10/17/2003 9:37 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The trick is to spin it over once with the choke on and ignition off, to prime the carb. When you crank it, you do it clockwise, and you need to always do it on a pull stroke so the crank doesn't rip off your arm or face if the engine backfires. You want to get the crank into the 7:00 position, turn on the ignition, then stand next to it on the passenger side, facing the windshield. Give it a solid pull upward, and let go once you reach 11:00. The engine will spit the crank outward if it starts, if not you want to shut off the ignition and reposition the crank for then next try. It can be dangerous, so don't hurt yourself.
#22618 10/17/2003 9:39 PM | | Anonymous Unregistered | | Anonymous Unregistered | I have started my '35 without problems on numerous occasions. The brake pedal return spring is weak and if I am not careful, it will run the battery down enough to where it wont crank fast enough with the starter to start.
I wire wheeled the crank end and pins and cleaned out the snout on the crank bolt and greased it so that it will kick the crank out when the motor starts. Just keep yourself clear when you do it and don't let it kick you! | | |
#22619 10/17/2003 10:19 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | | | |
#22620 10/17/2003 11:11 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Thanks Ralphy regarding thumb placement and earlier acknowledgement. | | |
