4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#22616 10/17/2003 9:31 PM
Who's started their engine with the hand crank ?
I'd like to start my truck with the hand crank, just for the antique show value, but I don't want to hurt myself. Any help ?
#22617 10/17/2003 9:37 PM
The trick is to spin it over once with the choke on and ignition off, to prime the carb. When you crank it, you do it clockwise, and you need to always do it on a pull stroke so the crank doesn't rip off your arm or face if the engine backfires. You want to get the crank into the 7:00 position, turn on the ignition, then stand next to it on the passenger side, facing the windshield. Give it a solid pull upward, and let go once you reach 11:00. The engine will spit the crank outward if it starts, if not you want to shut off the ignition and reposition the crank for then next try. It can be dangerous, so don't hurt yourself.
Paint & Body Shop moderator
#22618 10/17/2003 9:39 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have started my '35 without problems on numerous occasions. The brake pedal return spring is weak and if I am not careful, it will run the battery down enough to where it wont crank fast enough with the starter to start.
I wire wheeled the crank end and pins and cleaned out the snout on the crank bolt and greased it so that it will kick the crank out when the motor starts. Just keep yourself clear when you do it and don't let it kick you!
#22619 10/17/2003 10:19 PM
Thanks Guys
#22620 10/17/2003 11:11 PM
Thanks Ralphy regarding thumb placement and earlier acknowledgement.
