3 members (Lonnie, 3B, Leo),
72
Mod | | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I'm going with a 1987 blazer tank in my 51 under the bed behind the axle.
Has anyone done this already and if so do you have or know of pictures of the install ? Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Is that a 25 or 31 gallon ? Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | 25 gallon. There is a 40 gallon tank, but it hangs too low. | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | About how close is your tank from the ground ? I priced out a Aluminum tank and intank fuel pump and WOW $$$$. So I got a 1987 blazer 25 gallon/fuel pump. I think work out fine Thank again Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I used a 26 gallon military Blazer tank. There were no issues with ground clearance at all.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | In this photo the tank appears to be a tad low. However, that was before other suspension operations. I keep the bottom of the fuel tank no lower than 1-foot above pavement. If more weight, I just add air pressure to the air-shocks. Now, the truck looks right with the higher rear end because I raised the front end with Pro-Comp leaf springs, so the bed is more-or-less level.
As I think I mentioned previously, my mechanical fuel pump pulls fuel all the way from the rear tank with no problem. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would like to add a tank under the bed in order to get more mileage from a fill up. My major concern is how the filler will work. My body work is not good enough to bring it through the bed wall. I have considered a tank from one of those cars that had the filler behind the license plate. Has anyone seen that done?
~Jim
| | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Listen, BC3600, I'm like you in that I didn't want to fool with a bed wall filler cap. So, I just cut a trap-door in the wood floor for the filler cap and routed a hose to the fuel tank. No doubt there are slicker ways to do this, but 'crude but effective' always seems to work for me. | | |
