6 members (UtahYork, KEVINSKI, MikeStone1953, Jay R, 1955 1 Series, crenwelge), 354 guests, and 5 robots.
Topics128,159
Posts1,057,027
Members48,460
Today I inspected the inside of my 1951 fuel tank. I can see a heavy layer of varnish everywhere. I am sure that this crud will cause problems with fuel flow and contamination. Anyone have recommendations on products and or procedures as to flushing/cleaning/sealing my old "in the cab" tank would be appreciated.
Best Regards
Will
I would recommend buying a repop gas tank. I dont have any personal experience with it gumming things up, but I have heard A LOT of horror stories!
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
I agree!!! It is not worth taking a chance.A small amount off rust or crud can cause a big problem.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Riding in the Passing Lane
I agree. Buy a new one. I sent one out & had it cleaned & coated because it was in a panel & new was not available & now the coating is comeing off in the gas & gumming up the carb. I,m putting a new universal one in it now.
1972 Chevy c10 Cheyenne Super
In the past I have had pretty good luck with the local radiator shops. They can put just about any size tank in their vat and it comes out looking almost new.
Ex Hall Monitor
Ex Hall Monitor
Use the search function and you'll find a ton of info on this. Buying a new tank is the easyest and most expensive solution. Cleaning and coating your current tank is not difficult and if you follow the manufacturer's directions you will get a quality result. I've done several & never had a failure. Radiator shops around here won't touch gas tanks. Someone recently posted that they used steam cleaning successfully and didn't require coating.
If you want to try cleaning it up... hot, hot water and Red Devil Lye or Draino. Let it sit for at least a couple hours and it'll strip everything including neutralizing rust. I've let total rusty pieces sit for a couple days and they wash off without a speck of rust on them. I've even seen sendng units cleaned this way and work perfectly afterwards.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
I have used a company called Renu @ 1-800-997-3688 or www.gastankrenu.com with good luck.
Wanted Good Woman:
WillsLimo
read the thread titled...need to clean my gas tank.... lots of thinking, many points of view.
Good luck whichever way you go.
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
