3 members (Gib70, Nick in Manitou, 1 invisible),
356
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Today I inspected the inside of my 1951 fuel tank. I can see a heavy layer of varnish everywhere. I am sure that this crud will cause problems with fuel flow and contamination. Anyone have recommendations on products and or procedures as to flushing/cleaning/sealing my old "in the cab" tank would be appreciated.
Best Regards Will
| | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | I would recommend buying a repop gas tank. I dont have any personal experience with it gumming things up, but I have heard A LOT of horror stories!
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I agree!!! It is not worth taking a chance.A small amount off rust or crud can cause a big problem.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree. Buy a new one. I sent one out & had it cleaned & coated because it was in a panel & new was not available & now the coating is comeing off in the gas & gumming up the carb. I,m putting a new universal one in it now. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | In the past I have had pretty good luck with the local radiator shops. They can put just about any size tank in their vat and it comes out looking almost new. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Use the search function and you'll find a ton of info on this. Buying a new tank is the easyest and most expensive solution. Cleaning and coating your current tank is not difficult and if you follow the manufacturer's directions you will get a quality result. I've done several & never had a failure. Radiator shops around here won't touch gas tanks. Someone recently posted that they used steam cleaning successfully and didn't require coating.
| | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | If you want to try cleaning it up... hot, hot water and Red Devil Lye or Draino. Let it sit for at least a couple hours and it'll strip everything including neutralizing rust. I've let total rusty pieces sit for a couple days and they wash off without a speck of rust on them. I've even seen sendng units cleaned this way and work perfectly afterwards.
Lee | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have used a company called Renu @ 1-800-997-3688 or www.gastankrenu.com with good luck.
| | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | WillsLimo read the thread titled...need to clean my gas tank.... lots of thinking, many points of view.
Good luck whichever way you go.
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
