9 members (Hush, crenwelge, RoadsScholar, Gdads51, R&S 51 GMC, Otto Skorzeny, Hotrod Lincoln, Ponchogl, Gray_Ghost), 106 guests, and 1 robot.
Topics128,125
Posts1,056,343
Members48,441
#225929 01/29/2007 12:40 AM
Apprentice
Apprentice
To the people that have relocated there gas tank under the bed, what is all needed? The kit I am looking at is at http://tuckersparts.com/catalog.html?Iit=603&Ict=133 is there anything else I need? Is this a pretty easy install? Does anyone know of a better kit? Any help would be great. thankyou. Also if it makes a difference my truck is a 64 c10 short wide.
SGT Fraemohs, US ARMY
1964 C-10 short wide
#225930 01/29/2007 12:48 AM
Apprentice
Apprentice
#225931 01/29/2007 12:52 AM
That should be it except for the frame mod.s that you might have to do. I used a steel tank and welded in 2 cross pieces to help support it. I also ran all new steel (galvanized) fuel line to it and mounted it in insulated fasteners. I'm not quite to the body modification point yet so I can't help there,
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
