0 members (),
109
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 4 Junior Member | | Junior Member Joined: Jan 2007 Posts: 4 | im starting to build a 68 chevy shortbox half ton, i want to put disc brakes up front but not wanting to spend the 700 dollars for the conversion , where im at we have plenty of salvage yards and wondering if anyone could help me with any ideas on what later model stuff will work . I am planning on purchasing drop spindles and some 6 hole rotors . any input would be great | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt!
Though I've not lived there in 25 years I graduated from a Southern Idaho high school. What part of the state are you in?
I believe disk brakes were an option in '71 AND six-lug? I'm not sure of that, but I think someone told me it was the case.
Starting in '72 all Chevy/GMC 1/2-ton pickups have disk brakes, and the suspenion is the same basic design as your '68. But they are all 5-lug. I am sure of that, I have a '72 parked outside.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2007 Posts: 4 Junior Member | | Junior Member Joined: Jan 2007 Posts: 4 | im planning on purchasing drop spindles and 6 hole rotors , so if i robbed calipers off a newer model they should work? we are in buhl, i graduated here back in 84 . | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Caldwell ten years before you. I left Idaho at the end of '81 and have only been back to visit since.
I don't know if the later calipers and those rotors will work together or not. You might try to get your parts house to let you trial fit it at the counter.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '71s are 5 lug. It was the first year for disk brakes on Chevy trucks, they ware standard equipment. The '71s had a decal on the tailgate that was a yellow and black striped rectangle that said "Caution; Disk Brakes" on it. I remember that decal on my Dads '71 C20. GM also went to 5 lug on all 1/2 ton 2wd models, 4x4 stayed 6 lug but used disk brakes as well.
Bill Burmeister | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | I put spindles and disc brakes from a 84 C10 on my 65 C10. All I had to change was the ball joints and tie rod ends. The a-arms are the same. Direct bolt in job that took only a few hours. It's a 5 hole wheel now, but that is fine with me. I also used the 12 bolt posi rear from that 84. | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | I bought this kit from a Chevy truck supplier, consisting of bearing races and bolt-on plates for my solid-axle spindles. The rest (70s bearings and brakes discs) I bought new from Auto Zone. Got out real chaep! | | |
