2 members (MRMEROTH11, JW51), 70 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#225816 01/27/2007 9:13 AM
Junior Member
Junior Member
im starting to build a 68 chevy shortbox half ton, i want to put disc brakes up front but not wanting to spend the 700 dollars for the conversion , where im at we have plenty of salvage yards and wondering if anyone could help me with any ideas on what later model stuff will work . I am planning on purchasing drop spindles and some 6 hole rotors . any input would be great
#225818 01/27/2007 7:19 PM
Welcome to the Stovebolt!
Though I've not lived there in 25 years I graduated from a Southern Idaho high school. What part of the state are you in?
I believe disk brakes were an option in '71 AND six-lug? I'm not sure of that, but I think someone told me it was the case.
Starting in '72 all Chevy/GMC 1/2-ton pickups have disk brakes, and the suspenion is the same basic design as your '68. But they are all 5-lug. I am sure of that, I have a '72 parked outside.
#225819 01/27/2007 8:17 PM
Junior Member
Junior Member
im planning on purchasing drop spindles and 6 hole rotors , so if i robbed calipers off a newer model they should work? we are in buhl, i graduated here back in 84 .
#225820 01/27/2007 9:00 PM
Caldwell ten years before you. I left Idaho at the end of '81 and have only been back to visit since.
I don't know if the later calipers and those rotors will work together or not. You might try to get your parts house to let you trial fit it at the counter.
#225821 01/28/2007 2:16 AM
Z
Z Offline
yes they will work.
#225822 01/28/2007 4:50 AM
'71s are 5 lug. It was the first year for disk brakes on Chevy trucks, they ware standard equipment. The '71s had a decal on the tailgate that was a yellow and black striped rectangle that said "Caution; Disk Brakes" on it. I remember that decal on my Dads '71 C20. GM also went to 5 lug on all 1/2 ton 2wd models, 4x4 stayed 6 lug but used disk brakes as well.
Bill Burmeister
#225823 01/29/2007 2:02 AM
I put spindles and disc brakes from a 84 C10 on my 65 C10. All I had to change was the ball joints and tie rod ends. The a-arms are the same. Direct bolt in job that took only a few hours. It's a 5 hole wheel now, but that is fine with me. I also used the 12 bolt posi rear from that 84.
1965 Chevy C-10 Longbed Stepside
#225824 02/01/2007 7:24 PM
I bought this kit from a Chevy truck supplier, consisting of bearing races and bolt-on plates for my solid-axle spindles. The rest (70s bearings and brakes discs) I bought new from Auto Zone. Got out real chaep!
