8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | I have a 61 apache with this emblem on the hood.The thing is I don't see this emblem on other trucks. Can someone tell Me something about it? I hope this pic goes through! http://s154.photobucket.com/albums/s260/cfgilliam/ | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It almost looks like the emblem that they used on Brazil built trucks.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | Wow that sounds rare! The emblem is in good shape but I have a lot of work to do on the truck.Thanks Bill | | | | | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | CFG61,
What you have is a hood emblem that represents a V8 engine. This specific emblem was only available on the 60-61 Chevy truck hoods.
Since the majority of the 60-61 trucks had a In-Line 6 cylinder engine, they had the simple Bowtie emblem. The simple Bowtie emblem is very common, whereas the V8 emblem is somewhat rare.
Especially rare on the half ton. In 1961 the half ton had a 283 engine available, where the BIG bolts had either the 283 or 348 available. Percentage wise, the Big Bolts had more V8s than the half-tons from the factory. The very large trucks (ie semi-tractors,etc) had this same emblem only in larger scale size.
I could not tell from your picture if this hood was a BIG Bolt or a half ton. I assume the hood is from one of the larger trucks. Was/is there an original V8 engine in your truck?
Altho LONGBOX55 maybe correct about his Brazil comment, I have never heard or read that before.
Brian | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Yes, that is a V8 emblem. Let me know if you want to sell it. | | |
