0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#225419 01/22/2007 7:33 PM
Can someone explain the difference between the 3100, 3600, 3800 etc...? I thought a 3100 had to be a 1/2 ton and a 3800 a 3/4 ton but now I'm confused. Help me out here. Thanks.
1953 Chevy 1/2-Ton 3100 5-Window
1937 Chevy 1/2-Ton
1970 Chevelle
#225420 01/22/2007 7:35 PM
I thought it went like this..
3100 is a 1/2 ton
3600 is a 3/4 ton
3800 1 ton
#225421 01/22/2007 7:41 PM
additional series indications..
3700 is a 3/4 ton 'forward control chassis'
3900 is a 1 ton 'forward control chassis'
1.5 ton trucks are in the 4000 series, with the specific number based on the wheelbase
4100 1.5 ton 137 inch wheel base
4400 1.5 ton 161 inch wheel base
Two Ton trucks are in the 6000 series, again the specific number indicates the wheelbase.
The Cab Over or 'COE' trucks are in the 5000 series, and again, the specific number in the series indicates wheelbase.
#225422 01/22/2007 7:43 PM
Additionally, you can tell specifically what your truck is, by inputting the trucks serial number (found in the drivers side door frame) into The Stovebolt Page's VIN Buster found Here .
#225423 01/22/2007 7:47 PM
OK, this is a perfect opportunity for me to increase my "not so useless knowlege" file,...
I was under the impression that the number designation was roughly the tonnage capacity of a truck.
K10-half ton
K15-3/4 ton
K20-one ton
The numbers being tens of hundreds, or 1,000, 1,500, and 2,000 respectively (Thinkin these were later designations for the Chevy's tho).
Then in the bigger bolts, a 3100 would be a 1.5 ton & a 3500 a 1&3/4 ton.
Or,... am I gettin my numbering all screwed up with GMC here? I dunno, gotta ask tho so I can tell these things. smile
Also helps so I can finger out what trucks in the yard I can use to snag parts for my '56 2-ton! grin
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#225424 01/22/2007 8:17 PM
The "C" stands for conventional, or 2 wheel drive. The "K" is for 4x4 trucks.
10 - half ton
20 - 3/4 ton
30 - 1 ton
I'm not entirely sure on what the difference is between the 14/15 designation, although I know it has something to do with the bed style or length. I'm guessing that 14 is a short bed and the 15 is a long bed if my memory serves me correctly.
#225425 01/22/2007 8:23 PM
the numbers only relate to whatever the GM office team was smokin that day grin
the "x000" designations were earlier years, as Fumblin lists - the C, K, etc numbering started in the 60's and the 10's were 1/2T, 20's = 3/4T, 30's = 1T - the C=conventional 2wheel drive, K=4x4, P=panel or walkin deliv
C/K10 would be the short 1/2T series, C/K15 = long 1/2T and that numbering gets pretty complex adding all the variations of weight, length, 4x4, etc, complicated by the fact that the "C10" is the series, but followed by 2 more numbers indicating the exact model, so a C1434 is a conventional 2WD short 1/2T pickup
GMC used entirely different numbering
#225426 01/22/2007 10:17 PM
Yea.. the 'series' numbers that I mentioned above started in 1947 and were used up until at least 1959, when they were replaced with the 10 20 30 series numbers that started with a C or K to specify 2wd or 4wd.
Not sure when they started it, but I had a '67 'C10'.. so it had to have been between 1960 and 1967 they started that.
Then at some point.. in the late 80's (maybe 1988?) they appear to have dropped the 10 20 30 and went with 1500 for 1/2 ton, 2500 for 3/4 ton using C or K to indicate 2wd or 4wd.. at least for the 'full size' trucks.
#225427 01/22/2007 10:24 PM
I don't know all those Ks and Cs but my 51 3/4 ton 2 wheel drive is a 3600.
~Jim
#225428 01/22/2007 11:06 PM
The C/K lettering started in 1960.
#225429 01/23/2007 1:39 AM
Quote
I am pretty sure that the 3XXX designation started earlier than '47.
#225430 01/23/2007 5:53 AM
If it did, they didn't bother to put it on the trucks until '47 when the Advance Design trucks were introduced.
I've got stacks and stacks of info on truck models collected when I was building the VIN Buster, and the first time I saw the 3xxx designation appear in the data was beginning late 1947.
Altho that doesn't mean they didn't use it earlier, I just haven't come across anything indicating they did prior to 1947.. but I have heard individual truck owners use those series numbers to identify their trucks (i.e. saying '42 3100 instead of 1/2 ton)
#225431 01/23/2007 6:29 AM
Fumblin's right - before the AD's they just used letters for the series and model designation - see here
#225432 01/23/2007 3:03 PM
Must disagree with some of you. My 1958 1 ton is a model 38. A couple years earlier and it would be a 3800. A couple years later and it would be a 30.
I guess now the are called 3500's.
#225433 01/23/2007 4:52 PM
Not sure where you get that info Jhaa_lives, i'd like to see that documentation if you can get it scanned.
According to the information I have from various sources, including General Motors as well as the Stovebolt Pages' own TechTips section, the 1949 thru 1959 Chevrolet Trucks (U.S. Built) Have both a 'model' and 'series' designation.
In 1958, a 1 ton truck appears to have only come in one version and would have the following model & series designations:
Model.....Series.....Description
3G........3800.......135 Inch WB 1 ton truck
The serial number on the drivers door frame 'data plate' would start with these four characters:
3G 58
| Indicates model year
Indicates Model Number
Followed by a single character that indicated the plant it was made, followed by 6 digits that indicate production order.
#225434 01/23/2007 5:01 PM
Additionally, 1949 thru 1959 Model numbers consisted of two characters, a Number and a Letter.
1/2, 3/4, and 1 ton trucks started with a '3'.
A '3B' would be a Series 3200 truck.. which is a 1/2 ton truck with a 123.2 inch wheelbase.. slightly longer than the standard '3A' 3100 1/2 ton trucks 114 inch wheelbase.
#225435 01/23/2007 5:31 PM
not quite guys ... the number/letter combo started in 56, the 55.2 just had a single letter, and that setup was the series designator for paperwork like the vin, which doesn't indicate the model ... 3A or 31 both designate a 114" WB 1/2T, but might still be a pickup, panel, etc, which will be the next 2 numbers, which was indicated on the trim before 58 by '3100', like saying 31xx
jhaa_lives - in 58 they dropped the '00' for trim and advert purposes, the 38 was the series, and 38 series included: FF Cowl&Chassis, Cab&Chassis, PU Step Side, Panel, Stake, or W/S Cowl&Chassis - the next 2 numbers indicate which of those models
some 56 up trivia for ya:
31xx = short 1/2T
xx03 = chassis/cab
xx04= pu
xx05 = panel
xx06 = burb w/ barn doors
xx16 = burb w/ gate
xx24 = cameo
xx34 = fleetside
