9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22491 10/22/2003 1:09 AM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | This is probably a pretty basic question. How do you know if the springs need to be replaced> I am going to be doing the front end this winter and while I have everything apart... | | |
#22492 10/22/2003 6:46 AM | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | On my '37, the springs were pretty worn out from hard use. I could tell by looking at the bottom side of each leaf. The one below had dug into the one above and created a step. Over time it became deep enough to cause them not to move the way they should and ride rough. Spend a little time and take yours apart to look each leaf over. The new center bolts are cheap at the local trailer shop or spring shop.
I bought new springs this summer. I had them back out two weeks later because of the stiff ride. I removed the two lower leafs and applied grease between the others. The ride was 100% improved. Joe | | |
#22493 10/22/2003 10:12 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | I would like to know this also. I wonder if there is a measured tolerence. Like a certain ride hieght? | | |
#22494 10/23/2003 12:40 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I had a broken rear main leaf, and the other side had a bend between the shackle and second leaf. The unbroken side had notches in it from the second leaf digging into it. I found a pair of tonner rear springs in a junkyard that were only slightly notched and had a good curve to them. I disassembled the packs (which is a good idea if you find any rust in the centerbolt), and ground each leaf smooth with an wire cup brush on an anglegrinder. Eventually I got all the rust, burrs, and notches smoothed and I beveled the ends of the leaves (a bit more than they already were). Then each leaf got a bath in WD-40 to keep the rust off and a new centerbolt from Tacoma Screw was used to hold them together.
If your truck has been overloaded, it will have bent/flattened springs. Replace them. If it's just old and the notches aren't deep, you should be able to grind them smooth and reinstall. Remember to lube the springpacks with the rest of the chassis and they can last forever. | | |
#22495 10/23/2003 12:47 AM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | "they can last forever." It's easy to tell on my truck. One side sits higher than the other. | | |
#22496 10/23/2003 1:40 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Remember also to check the eye bolt holes in the main leaf. If the hole is worn past the bushing into the leaf itself, it is time for new springs..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#22497 10/23/2003 3:01 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your front springs should have a good arch to them, sitting under load. My springs were pretty near flat sitting under load and the shackles were almost at full travel. Obviously I had to replace them. | | |
#22498 10/24/2003 4:58 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I'm planning to also address my front leaf springs and noticed you comment TRUCKERNIX about the front underload. Mine are current perfectly flat underload, thus I assume it's time to replace? I have another set that came out of a '53 which I might try installing to see if they still have any arc left in them. Hmmmm....
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#22499 10/24/2003 9:33 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yeah , my fronts are flat too ,, but the spring shop says thats right ,, something to do with the steering geometry and bumps and stuff ,, and it steering straight ,, which it does ,, so they left it all alone ,, check out the ride height in the pic in the gallery . | | |
#22500 10/24/2003 11:06 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you look at the way springs work, they flex and the arc starts to straighten out under greater force. When this happens, they lengthen eye to eye. If the springs are flat at rest, and the shackles are at full travel, the spring would have to bend backwards or upward and I don't think that they are designed for that. Certainly, the AD trucks are not designed that way. | | |
#22501 10/25/2003 1:37 AM | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Dusty, you do good work! That bed and the whole truck look great. My grandfather & great-grandfather were carriage & wagon builders and wheelwrights. They continued their trade with the advent of the automobile, building truck cabs & bodies. I think they would have highly approved of that bed! Post a picture of the truck when you get the canopy up.
Union, Justice and Confidence
#22502 10/25/2003 5:17 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Thanks for the info about evaluating the springs. As I was looking at them today I have another basic question. As I do the from end with the possibility of removing the axle , springs, etc. Where do I put jack stands or blocks to support the truck? | | |
#22503 10/25/2003 5:28 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I put jackstands under the framerails and then a floorjack under the front axle. That way you can raise and lower it to take the pressure off the springs when needed.
54 3100 with 235 62 flatbed dump C60 with 261
#22504 10/25/2003 6:06 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | TonyM. Thanks for the reply. It seems that the only available spot to put the jack stands are quite away back from the front end of the truck. I think they would have to be behind the leaf springs. Is this too far back? | | |
#22505 10/25/2003 6:06 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M, Where under the frame rails? Back behind the front wheels in front of the cab? I'm looking at this issue right now and see that if you're removing the springs, there is a very limited number of places that the stands can be located without creating a interference. Too far back and you approach potential pivoting problems.
#22506 10/25/2003 10:25 PM | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Before you who have 'flat springs' go ahead and replace...don't. I did with brand new and they're still flat. I agree with Dusty and the shop that told him "...that's the way it's supposed to be."
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#22507 10/26/2003 1:04 AM | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | The '37 Engineering Manual talks about a flat spring under compression and the benefits they profide to the steering and ride. Don't change them if the are flat. Joe | | |
