1 members (1 invisible),
93
Mod | | | Forums66 Topics128,188 Posts1,057,217 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Somebody must know a sure-fire way to remove the kingpins from a 55 1st series Chevy axle.
I finally got the locking pins out but now the kingpins will not even begin to move.
I don't really know whether to heat the axle or not and I can't get to the pin to put heat directly where it needs it.
Anybody know how to overcome 52 years of frozen rusted steel? thanks!!!!
slowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | slogoer,
It's alright to apply some heat to the axle 'eye'...it's a forging and was born of heat!
Doing this job while the axle is on the truck, and swinging room is at a premium is twice as tough.
Heating the eye, spraying with WD-40 or the equivalent and beating with a very large hammer and piece of bar stock is about it.
The king pins are supposed to be tight in the axle eye..if yours are, count your blessings.
Taking the axle off for serious beating, or a trip to the machine shop isn't that difficult, and can save knuckles and fingers.
The hubs and backing plates will be pulled anyway when you clean and re-bush the spindles and it gives you a chance to inspect other components.
The key on this project is to out think the king pins. If they detect a weak spirit, they will not move. Good luck.
Stuart | | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Thanks Stuart, I guess I will put the heat to it and get a bigger hammer. You are right about limited space, it is tough to keep from taking chunks out of the fender but I do not want to take it off. mitchell
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I think some guys use a bottle jack and the weight of the truck to push the pin out. Never used that method myself though... | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | A bottle jack and a lenth of chain works great. Be careful though the jack will try to turn if the chain is not just right. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A lot of the impact depends on the type of drift that you are using. Mild steel will absorb a lot of the energy intended to move the kingpin. I found something hard like a wrist pin worked well. Also, with all the pounding, it is possible to distort the wrist pin a bit, and driving it through can affect the bore. My advice is to get it started moving and then remove it in the reverse direction. You can tell when it has started to move. Initially your hammer will bounce and when the pin starts to move, the hammer won't bounce the same. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have always taken the front axle off the truck and pressed-out the kingpins; however, Koolkar has a Tech Tip for kingpin removal that many people say works like a charm. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | P-B buster over several days. Me being a welder I made a pusher out of some pipe and 1/4X 1 flat welded on each side of the pipe with nut and bolt welded on the top to screw pressure on the pin. Like a bearing puller excep oposit. The old grease acts like an adheasive when old. P-B will lossen it up over time.I don't like hitting something that hard cuz I always mis the drift and hit my hand and so it makes it more painful to make the tool, so I make the tool first. Need a drawing let me know. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | According to the shop manual you NEVER, EVER apply heat to a forged axle. It weakens it. Check out the new Tech Tip on this very subject, link is at the top of the page. Good luck! | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Got mine out using a large u-joint seperator I got cheap, and a hammer. Tightened the clamp with a BIG breaker bar, then whacked the screw with the biggest hammer I had.... Four or five repeats and the pin kept sliding with turning the screw. Ruined a cheap tool (still have it, though), but got the job done.
Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | That KoolKar tip sounds like it will work so I think I will try that first Thanks !!
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Be careful about spraying wd-40 around a torch, it burns you know...
| | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | If you can't remove them easily on the truck, remove the axle and take it to a machine shop to have them pressed out. This is the best and least damaging way to do this repair. Unless you're experienced and educated about what heat does chemically to steel, you shouldn't heat it over about 250 F. If you heat it above that, trust me, you damage it and make it unsafe to drive.
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
| | | | | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | This is how I just recently removed mine. 1. Place axle onto jack stands. 2. Remove all the stuff so only the spindle is left. 3. Use a floor or bottle jack with a heavy chunk of iron, such as a sledge hammer placed on its side on top of the jack and then jack up to the bottom of the king pin [after you take the plugs out], jack until you take the weight off the the jackstand, whether it be the left one or the right one. 4. Place a slug of close to the same diameter on top of the kingpin, I used a 1/2 or 9/16 nut. There will be about 1/4 of an inch of the nut sticking up above the knuckle. 5. Beat on the nut with a 4 or 6lb sledge. I am sure it will start to move for you. the key is to have something real heavy on the bottom. I used a post pounding mallet head that weighs 14lbs. 5. Once you have the kingpin pounded flush to the bottom of the knuckle, you will have to place a short piece of pipe a little larger inside diameter than the kingpin outside diameter, between the bottom of the knuckle and your chunk of iron and jack. 6. On top I used a 3/4 inch bolt, held with vise grips and carried on beating the pin out. It worked for both sides.
Good Luck, Brian | | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | I just replaced my kingpins in my '53 and I used a 1/2" deep impact socket , which was very slightly less in diameter than the kingpins and beat the hell out of it while holding it with a pair of vise-grips, about 3-4 whacks with a 2 1/2 lb sledge and both kingpins came out real nice , this was on a truck that hadn't turned a wheel since '72 | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | I'm with Ron. I had mine pressed out at the machine shop. 20 tons of force was needed on a 40 ton press. Cost: $40 bucks. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | I may be wrong here but don't the Kingpins have a TAPPER?? Also make sure that the locking pin has been removed or you could drive it for a month and it won't move. I have removed quite a few kingpins and I can tell you hitting your thumb with a 2.5 pound sledge hurts way more the second time you do it, usually followed by several words that would make a longshoreman blush and a dent in somthing else.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Taper?
No, not in a 1/2 ton 55-1st series Chevrolet truck. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Sometimes it helps to whack the eye end of the axle with a big hammer.
Mine took a 20 ton press. It made funny popping sounds and then let loose.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I always had success taking the axle off the truck. I then put an appropriate sized bolt in the axle bore and smacked it real good using a 22 ounce framing hammer. Of course, I always needed to do other fixes to the front end.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think our flyboy from Alberta has the right idea, might be difficult to find a suitable puller heavy enough to press the king pin out if it is really stuck bad. When I changed mine they tapped out with a brass punch, they were nice and snug but not at all frozen. In my opinion you should not use anything harder than brass to remove a steel pin of any sort. If you use any steel or hardened steel drift you will most likely start to mushroom the king pin and then it just gets tighter and tighter being similar to what happens when you upset a rivet. I'm fortunate to have access to a machine shop so I have duplicated most of the Special Tooling pictured on the pages of the Shop Manual for working on the various components of my 1950, 3604. The latest go round are the tools for working on the rear axle, i.e., hub bearing and seal removers and drivers and six point adjusting nut spanner. I also made the properly sized seal, bearing race drivers for the front wheels, and mast jacket bushing remover and driver. Torque tube seals and bushing were another set. If I had a king pin that were frozen to the point that a brass drift would not budge it, I would machine a puller fashioned after a pitman arm puller that would capture the eye with a large, probably 3/4" thread to press the pin out. If that didn't work I'm sure that some sort of a saddle could be rigged with a 20-ton bottle jack from HF a couple of plates and some threaded rod. Of course I've been called a bullhead by more than one person close to me and always want to do it myself. Then again, not everyone has a machine shop at their disposal, in that case I'm with Ron, pull the axel and take it to someone with a press. I concur TC, never any taper. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Just thought I would let you know that the KoolKar tech tip works. Letting the weight of the truck work for you helps alot. Thanks again for all the info! mitchell
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Glad to here you got em out!  I tried to do mine once on a 59 gmc... ended up taking the axle to a machine shop to have em pressed out after a lot of colorful words. I just pressed the king pins out of a 1941 axle at a machine shop I have access to. It sure beats swinging a hammer!!!  The Axle is off to the powder coater now to get blasted and powder coated, before I reinstall the king pins. Congrats! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have found that #@#@#@#@# works for me.
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just as an addendum to this thread. I was at a winter swap meet last weekend and noticed a couple of control arm bushing remover/installers that one of the vendors was selling. One of them looked like it would work great for popping out a stubborn king pin. You would have to make an adaptor the size of the pin, but the anvil is super heavy. Bout $70 bucks, might pay for it self if your planning a few restorations or if you have friends that you like to loan your tools to. Try these pics and see what ya think; http://rides.webshots.com/photo/2861149360098611668JfIjQY http://rides.webshots.com/photo/2090331440098611668iTMoyD Denny Graham Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Originally posted by Denny Graham: If that didn't work I'm sure that some sort of a saddle could be rigged with a 20-ton bottle jack from HF a couple of plates and some threaded rod. Of course I've been called a bullhead by more than one person close to me and always want to do it myself. Then again, not everyone has a machine shop at their disposal, in that case I'm with Ron, pull the axel and take it to someone with a press. I concur TC, never any taper. Denny Graham Sandwich, IL As I posted above. I have had good luck with a bottle jack and some chain. Used the chain for the saddle as Denny here describes. My experience with king pins has been on much bigger 18,000 lads axles so this should work for an axle designed for 4,000 lads. | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | just get a kingpin press or ujoint balljoint remover sometimes they are called. its a big c clamp made for that you can get them fairly cheap like 39 bucks from harbor freight,,, wait.. i got mine on ebay for 39 bucks ya cant go wrong... removes ball joints or ujoints also... the one guy before mentioned it but no one picked up on it... like this ebay press
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
