Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Lightholder's Dad, Donf, baldeagle, JW51, UtahYork), 35 guests, and 1 robot.
Topics128,005
Posts1,055,253
Members48,418
#224712 01/16/2007 6:41 AM
Hey All! I'm thinking about lowering my '65 Short stepside about 3" in the back, 2" in the front, using shorter spring/shock kit sold in LMC and similar suppliers. Are there any alignment concerns using springs instead of drop spindles? Any help is appreciated.
#224713 01/16/2007 7:15 AM
Hi Timmy,
You will have some alignment to do, but it isn't serious. Go ahead with the project then align when you get a chance. Do so before too long so your tires don't wear unevenly up front. It will steer fine and be safe but will need camber and caster adjustments (If I remember, they tilt in at the top when lowered, causing wear on the inside bottoms).
Make sure to get the adjustible tracking arm for the rear end...as your truck comes down the rearend will shift towards one side.
Hope that helps.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
