| | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I would like to remove the vent windows on my 51 and switch over to a one piece window I know that the 47 thru 50 had a one piece. Will the windows & tracks & regultors fit in my doors OR does anyone know of a kit ? Thanks Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The regulators are different shape and size and there is a vertical forward edge track that is part of the vent window frame, inside the door. This would have to come out. The sheet metal on the sill of the doors is different with the vent window door because of a tab which holds the vent window latch. The inside window frames are slightly different as there is a notch cut out of the vent window model frame. Of course the glass is different. IMHO it would be easier to change the whole door if you have access to them. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Try to run a search on this subject, as I remember it being discussed before. And I belive it involved considerible work to make this switch. | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | A place called nu relics sells a power window kit that will eliminate the vent window. Here's the link to their site: http://www.nu-relics.com/ct47_50_2.html hope this helps | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Still would take some modification to the door. As I wrote they are not quite the same. | | |
