8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
1 Offline
I would like to remove the vent windows on my 51 and switch over to a one piece window I know that the 47 thru 50 had a one piece. Will the windows & tracks & regultors fit in my doors OR does anyone know of a kit ?
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
The regulators are different shape and size and there is a vertical forward edge track that is part of the vent window frame, inside the door. This would have to come out. The sheet metal on the sill of the doors is different with the vent window door because of a tab which holds the vent window latch. The inside window frames are slightly different as there is a notch cut out of the vent window model frame. Of course the glass is different. IMHO it would be easier to change the whole door if you have access to them.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Try to run a search on this subject, as I remember it being discussed before.
And I belive it involved considerible work to make this switch.
1949 Chevy 6400
1931 Chevy Firetruck
A place called nu relics sells a power window kit that will eliminate the vent window. Here's the link to their site:
http://www.nu-relics.com/ct47_50_2.html
hope this helps
Still would take some modification to the door. As I wrote they are not quite the same.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
