| | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 7 New Guy | | New Guy Joined: Jan 2007 Posts: 7 | Does anyone have a good set of plans / specs for wood sideboards for a 52 3600 longbox. I have seen a few that look nice, but I don't know what is correct.
jbc52 | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | I just made mine to fit.
As far as I know, sideboards were never offered as an option, and probably weren't even made after market, except by the owner. Which opens up a world of possibility for you -- you can make whatever you like and it's no less correct (as long as your hardware is correct for the period) than anyone else's.
Lots of guys have made their own -- cruise through the Gallery (use the menu bar above) and see if any in there fit your liking or give you ideas.
And welcome to the Stovebolt Page, by the way!
Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I put a photo on my site: http://s32.photobucket.com/albums/d41/coilover/ Scroll down to the first pic to see a side view but the one that may help is on page 3. The verticle 2x4's are trimmed equally from each side to center in the stake pocket hole and then angle cut at the bottom to fit the angled side. The horizontal side boards fit in dado cut grooves in the vertical boards to eliminate the wobbling and looks nicer. Carriage bolts look nice on the joints but screws and carpenters glue would be fine also. Hope this helps a little.
Evan
| | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | jbc52. my grandfather built these grain side boards for his truck. http://www.stovebolt.com/gallery/heiden_pj_1950.htm nothing fancy but as far as i know they've been on the truck since the 50's. i've repainted the side boards since these pictures were taken, but you get the idea. if you want i could send you some detial pics of how it goes together. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | here's my favorite side boards of all time........ Sideboards ......and more.....
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
