2 members (klhansen, 1 invisible), 151 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
V
V Offline
I know that you all know most everything about trucks so I'm going to ask you. I am looking for the name of a type of steel for the running board on my old fire truck. I need a piece to cover the rear where the hose bed goes on and lines up with the rear step. Anyway, I don't know what they call it. I know diamond plate is used on our new firetrucks but what is this stuff called and where might I purchase a 6'x 1' piece? Picture link: http://rides.webshots.com/photo/2382042990080243953lXxyvT
diamond plate
but there are many designs depending on the manufacturer
avail in rubber coat ........... but that was not stock back then.
http://images.google.com/images?q=d...;lr=&sa=X&oi=images&ct=title
Jim & Caroline
I've heard something like that called checkerplate.
1951 3800
-hotshoe
Do a search of floor plate or checker plate.
Check out this site.
http://www.gratingpacific.com/diamond_floor_plate.htm
V
V Offline
Thanks folks! I'm on it.
I think that the stuff with the little square raised bumps rather than the diamond pattern looks better on old trucks. I have an old fuel tank I can take a picture of with the square stuff if you would like to see.
I don't know if you can buy it now days though?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
V
V Offline
Grigg: Thanks. I'd like to see a picture. I do not want diamond plate on the old truck. I'm going to try to get some made if I can't locate some. I'm trying to find a piece to replace some of the rear of the truck running tail board.
V
V Offline
I would like to thank Grigg for donating the checkerplate steel fuel tank(see above post) which I need to finish the rear step on my fire truck. I met him today and he provided the steel that I have been hunting a long time.
Thank Grigg! Just one more outstanding example of the Stovebolt members.
