| | | Forums66 Topics128,118 Posts1,056,306 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I know that you all know most everything about trucks so I'm going to ask you. I am looking for the name of a type of steel for the running board on my old fire truck. I need a piece to cover the rear where the hose bed goes on and lines up with the rear step. Anyway, I don't know what they call it. I know diamond plate is used on our new firetrucks but what is this stuff called and where might I purchase a 6'x 1' piece? Picture link: http://rides.webshots.com/photo/2382042990080243953lXxyvT | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | diamond plate but there are many designs depending on the manufacturer avail in rubber coat ........... but that was not stock back then. http://images.google.com/images?q=d...;lr=&sa=X&oi=images&ct=title
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I've heard something like that called checkerplate. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think that the stuff with the little square raised bumps rather than the diamond pattern looks better on old trucks. I have an old fuel tank I can take a picture of with the square stuff if you would like to see. I don't know if you can buy it now days though? Grigg | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Grigg: Thanks. I'd like to see a picture. I do not want diamond plate on the old truck. I'm going to try to get some made if I can't locate some. I'm trying to find a piece to replace some of the rear of the truck running tail board. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I would like to thank Grigg for donating the checkerplate steel fuel tank(see above post) which I need to finish the rear step on my fire truck. I met him today and he provided the steel that I have been hunting a long time.
Thank Grigg! Just one more outstanding example of the Stovebolt members. | | |
