1 members (baldeagle), 35 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#222993 12/30/2006 1:42 AM
I have a 65 C10, and the engine pulled from a 71 nova SS, the 350. . . I need to pull off the POS 3 speed manual, and I'd like to put on a turbo 350 transmission. . . will I be able to bolt on a 4 speed? or will this involve a ton of customization?
Appreciate what you have, work for what you don't
My \'65 C10 350
#222994 12/30/2006 1:52 AM
it'll bolt to the block just fine.
you might have to do some cross member work as well as some adjustment on the the drive shaft length.
some of the guys from that era will chime in here...
edit - if it were up to me, i'd keep the ckutch and change it to a floor shift...
#222995 12/30/2006 1:56 AM
I should have mentioned that. . . it is changed to a floor shift
My \'65 C10 350
#222996 12/30/2006 2:06 AM
J M Offline
You will have to replace the flywheel with a flex plate to hook up the torque converter, and possibly the radiator with a transmission cooler as well as the shift linkage. As was allready mentioned, you might need to change the crossmember as well as the drive line. Over all it should bolt up just fine. with a few changes that shouldn't be to hard to fine and do.
Jim
