1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
I have checked all my local auto parts suppliers and nobody carries 1 3/8 inch fuel hose,
I need to replace the filler neck hose on my Advanced Design truck.
You would think with hundreds of thousands of vehicles built using this size hose someone would have it.
My friend used radiator hose for his and I guess with so little exposed that is an option but I would feel better about the proper material
Is there a difference?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Every single single parts supplier for Advance Design trucks have them.
Steve
'49 3800
'52 3600
'57 3100
Chev's of the 40's (good folks to do business with) have them for $10.25, if you're not doing a correct resto I like the radiator hose idea.
I think you would be better off getting the correct type hose from one of the venders. The rad hose would probably get you by, but some of the stuff they put in todays gas is very corrosive to rubber, unless it's made for fuel use. Especially ehtanol. Not only could you end up with fumes in the cab if it eats though, but anything that it dissoves will end up in the tank and fuel system. If you do want to try the flaps, ask for fuel filler hose rather than fuel line. Sometimes you gotta be absolutly specific with those parts guys or you'll either get a "we don't have it" or a "it doesn't exist" answer.
Bill Burmeister
1 Offline
go to you local hydraulic hose supplier they will be able to help you or direct you to a source.
I got it special ordered through a parts store,
and it must be for gasoline usage...I bought a foot
of it, and used only about 4-5 inches..
My original hose I couldn't brake it loose, it had only been there 50 plus years...so I took a razor knife and split it...It has GM on it with the part number there too... :mad: BB
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
OOPS sorry, I bought it at Carquest or NAPA.
Quote
Yes.
"It ain't a truck if you can't hose out the cab."
Take your old one to the rubber store in your area.
They can make one up for you.
I believe you want to use neopreme hose and not rubber.
1951 3100 Chevrolet
Z
Z Offline
gas is a good solvent.i used gas hose from carquest.
