1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#222801 12/27/2006 11:25 PM
Trying to get 55 years of build up out of my gas tank....Anybody have any good solutions to mix together to take the scum out....besides buying a new tank...
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#222802 12/28/2006 12:49 AM
Never hurts to do a search of past threads on your topic.
A search using 'gas tank cleaning" found this thread which should get you started on some ideas.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005616#000000
Others may chime in with more info.
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#222803 12/28/2006 1:07 AM
I have said this before but no one seems to believe me. Gas tanks can explode like a BIG bomb. Some jobs are not suitable for do it yourselfers. Take it to a shop that specialises in tanks and let a pro do it. Better spend a little money than get your head blown off.
I like old trucks
#222804 12/28/2006 1:16 AM
I agree with Bullet about a gas tank being a bomb. If its not to bad and your trying to get varnish out I have had luck mixing tolulene with gas and flushing it thru. But again, make sure things are vented and use caution.
#222805 12/28/2006 1:16 AM
I think if you call a radiator shop they can clean & flush the gas tank, and you don't have all that mess to clean up & dispose of.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#222806 12/28/2006 1:38 AM
Ex Hall Monitor
Ex Hall Monitor
Radiator shops around here won't mess with gas tanks. Your best bet is an acid cleaning & coating the inside of the tank. You can buy kits that use phosphoric acid as the cleaner. I've used Kreem's kit and I've also made my own "kit" using Muratic acid then RedKote to line the tank. I prefer RedKote. As Randy noted above, doing a search will get you more info on this subject than you can shake a stick it.
#222807 12/28/2006 2:27 AM
Thank you for all your answers....I ended up buying a new tank..."Brothers Truck Supply" is 20 minutes way...It took me 40 minutes round trip for a new tank..and no mess...
1951 3100
Pablo Picasso
#222808 12/28/2006 5:44 PM
yea. and no half corroded metal worn thin.
"It ain't a truck if you can't hose out the cab."
#222809 12/28/2006 5:51 PM
Junior Member
Junior Member
Holcomb,
Glad the new tank worked out for you. For the record, I have had success by putting a section of chain (3 or 4 feet) in the tank and shaking it around. Flush. Repeat.
I wouldn't recommend drugs, alcohol, and violence to anyone...but they've worked well for me.
#222810 12/28/2006 7:04 PM
Tip: A lighter is not an acceptable form of light to look inside the tank. HEHEH
#222811 12/28/2006 7:27 PM
Kcwelshans,
thank you for your reply
I tried using the chain, lug nuts mixed with cleaner...but my patients sometimes whats it now....so I gave up...and went with new...My wife sometimes may drive this truck...so I need to make it girl friendly...even though she is a farm girl...can't have her stuck
1951 3100
Pablo Picasso
#222812 12/28/2006 7:51 PM
If a guy had an old paint shaker.You could rig it to fit the tank.I bet that would get the scum loose.
1951 3100 Chevrolet
#222813 12/29/2006 2:46 AM
Just a thought, as I see you've bought a new tank.
I've had good luck hanging the tank up about 3' off the ground, between two trees or an a-frame, filling it about half full of hot water, dropping in some lug nuts, putting 3 or 4 ounces of dish washing liquid in, and swinging it side-to-side and back-and-forth.
Tie a lenght of rope to each end so you have something to grab hold of. It makes it easy to twist and to bring it to an abrubt stop, causing the lug nuts to really move around.
Alot of the time , by the time you finish you'll also know if there are any really rusty spots in the tank, because you'll see a leak.
