3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#222586 12/24/2006 4:58 PM
I have a 46 with a chrome T handle on the dash. Is it for opening the fresh air vent on the hood? If it does, mine must not be connected.
Dan Mascheck
Wharton, TX
#222587 12/24/2006 5:19 PM
Dan is this handle on the top of the dash??? Or is it under the dash?? If it is on top it should not be a T handle but a small window type crank for the windshield regulator. The cowl vent is a push pull lever under the center of the dash. Got a Picture of it??
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#222588 12/24/2006 8:31 PM
Maybe it's a twist-lock cable for a PTO or hand throttle.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#222589 12/25/2006 8:35 AM
I do believe this is the passenger ejection seat release on Bond models. grin
Haven't had a chance yet to welcome ya yet 46Dan..welcome! Not sure what that would be..about that picture.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#222590 12/25/2006 2:54 PM
The T handle is lower down on the dash and has to be for the fresh air vent. It is a push pull style control. It must not be hooked up. I can see the opening on the hood.
I know there is a crank on the top of the dash to move the window forward. It's a great feature in the fall!
Dan
#222591 12/25/2006 4:54 PM
"the opening on the hood"? the air vent is on the center of the cowl, and is operated with a lever/handle that's under the middle of the dash - no air vent on the hood - what you have may be a disconnected choke or throttle cable
might want to check around Brad\'s 41-46 site for more info about your year
#222592 12/25/2006 8:15 PM
Does the T handle "swing" forward under the dash? 'Cause that would be your cowl vent. If it is a push pull then I go with a later added choke handle, or something added later, not stock.
1947 Chevy COE
#222593 12/26/2006 12:40 AM
It's in the lower part of the dash, not under it! I'm almost positive it's for the Cowl Vent on the hood and is not hooked up.
Thanks!
Merry Christmas!!!
Dan
#222594 12/26/2006 7:22 AM
Dan I will get you some pictures tomorrow and see if we can identify the item in question.
Hope you and yours had a Very Merry Christmas
#222595 12/26/2006 1:03 PM
Quote
"My name is BOLT, ..... Stove BOLT!"
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#222596 12/26/2006 2:45 PM
Pretty neat if it is. I wonder if it will work on the Wife when we are riding togather! SLAP SLAP!! I need to get those thoughts out of my head.
I need to look under the dash and see if there is a lever underneath for the cowl scoop. I just assumed the T handle was for the scoop. It still leaves a mystery on what it's for.
It's just a tiny stainless or chrome, small about 1.5 to 2 inches long T handle. It pulls out, but nothing happens. It amazes me that no one else seems to have one. It's mounted on the lower part of the dash. I need to get a picture of it!
The mysteries of life!!
Dan
#222597 12/26/2006 3:40 PM
Sounds exactly like the inside door lock knob from the driver's side door. Can you send a photo
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#222598 12/26/2006 5:04 PM
Why would they have a lock for the driver side door in the lower center of the dash! Seem too advanced for 1946.
Surely somone else has the tiny T handle. It does not look like something that's been added. I do also have the crank for the windshield some have talked about.
I need to take some pictures so everyone knows what I'm talking about!
Dan
#222599 12/27/2006 1:13 AM
You can perty much bet on it being an addition to the rig. Do you have a PTO on the transmission that needs an actuator? Most trucks have a push/pull for activating the PTO. How big is the cable coming off the handle and where is the other end of it?
#222600 12/27/2006 3:04 AM
It may be an add on, but it looks like part of the original issue.
I did notice the cowl vent has had the lever everyone talks about removed or lost. I need to see if I can get a replacement!
Dan
#222601 12/27/2006 3:06 AM
46Dan. Guess I was not very clear. The “T” handle that you describe sounds like the inside door lock handle on my ‘41’s driver side door. It is located directly inside of the outer door handle. I was only suggesting that the handle you describe looks the same. In the center of the dash in the area just above the ash tray you should have 4 round openings all in a row and all roughly the same size. They are ignition switch, throttle, choke, and an extra opening for a heater or other optional switch.
